Re: [Release-team] Status of initial tech doc testing
I've re-generated the nginx config. The only difference I saw was the addition of the microbes_model_builder which looks like a lab (versus a service) and doesn't have any typical service documentation. Was there anything else missing? I've fixed the broken links for all but FBA. FBA doesn't appeared to be deployed. I wasn't sure if there was a reason for that. --Shane On Aug 7, 2013, at 9:14 PM, Thomas Brettin <[email protected]> wrote:
-------- WARNING: At least one of the links in the message below goes to an IP address (e.g. 10.1.1.1), which could be malicious. To learn how to protect yourself, please go here: http://www.lbl.gov/cyber/services/suspicious-links.html --------
Can someone on the sys admin team fix this?
Thanks, Tom
On Aug 7, 2013, at 6:58 PM, Michael Sneddon <[email protected]> wrote:
Nearly all of the services that have been deployed passed the initial doc testing.
The two exceptions are 'sim_service', which is not deploying API docs at all (needs to add the proper doc generation and deployment code to its Makefile), and 'search', which was deployed to a test VM that I couldn't find (not available from t1 by ssh search ??), and has no docs appearing here: http://140.221.84.191/services/docs/search/
In addition, several modules do have proper documentation that seems to be properly deployed, but is not appearing here: http://140.221.84.191/services/docs . It's probably just a proxy issue, but here is the list of those modules:
auth_service cluster_service expression KBaseFBAModeling plant_expression_service
_______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
participants (1)
Shane Canon
