The runtime has grown quite a bit. It also may be larger due to building on mountain lion instead of snow leopard; I suspect there may be more 64-bit built stuff which may increase the size of the executables. If I can get a snow leopard build machine again I'll be doing builds there (I'd like to have a copy I can use ...) Thank you for poking at it. --bob On Oct 11, 2013, at 1:02 AM, Nomi Harris wrote:
The previous dmg was 257M; this one is 1.04G. Why is it so much bigger? (And the installed image is 2.8G! Whoa!)
I did a very basic sanity check--I was able to download, install, and launch it (all of those took a while, since it's so huge), and it brought up a terminal window as expected, and it responded appropriately to the few kbase commands I typed.
Nomi
On Oct 10, 2013, at 9:41 PM, Robert Olson <[email protected]> wrote:
is at http://bioseed.mcs.anl.gov/~olson/20131010-prod-dmg-2.dmg
This is cut from the following tags:
KBaseFBAModeling 20131010-prod assembly 20131010-prod auth 20131010-prod cbd 20131010-prod communities_api 20131010-prod functional_ortholog_predictor 20131010-prod genome_annotation 20131010-prod genotype_phenotype_api 20131010-prod idserver 20131010-prod invocation 20131010-prod jnomics 20131010-prod kb_seed 20131010-prod kbapi_common 20131010-prod kbrest_common HEAD m5nr 20131010-prod networks 20131010-prod ontology_service 20131010-prod phispy 20131010-prod plant_expression_service 20131010-prod probabilistic_annotation 20131010-prod sim_service 20131010-prod translation 20131010-prod trees 20131010-prod typecomp 20130926-test workspace_service 20131010-prod dev_container_tools HEAD kb_model_seed 20131010-prod jars HEAD strep_repeats HEAD erdb_service 20131010-prod
I have not been able to test since the build machine is running mountain lion; the runtime as compiled there will not run on my snow leopard machine.
--bob _______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
participants (1)
Robert Olson
