Re: [Release-team] request to put KB Protein Structure Service
Hey you're right - it works from my home. I wasn't able to connect previously (from BNL, same exercise on a different instance, also Havana - same symptoms, localhost:7088 worked fine, internal request to IP hung up, and external from BNL did as well. Its possible I mistyped the address then). Thanks! On Sat, Jul 12, 2014 at 4:48 PM, Murphy-Olson, Daniel E. <[email protected]> wrote:
The external address seems to work for me from an outside connection.
________________________________________ From: Sean McCorkle [[email protected]] Sent: Saturday, July 12, 2014 3:30 PM To: Brettin, Thomas S. Cc: [email protected]; Murphy-Olson, Daniel E. Subject: Re: [Release-team] request to put KB Protein Structure Service
Okay, done. Its in the repo now. I tried a clean build on a fresh VM instance (using Havana) and every test checks out,up to the client -server network connection on port 7088. A connection to http://localhost:7088 works fine, but not one to the assigned IP address http://140.221.67.170:7088, and I can't get that to work externally either. I suspect I'm doing something wrong with the Havana security group rules or something. (I don't think the issue is in the service code)
Thanks again! =sean
On Sat, Jul 12, 2014 at 10:49 AM, Sean McCorkle <[email protected]> wrote:
No problem at all to change the name - I'll make the deployment directory
/kb/deployment/services/protein_structure_service
to match the repo name, and I assume the "official" url will have the same name as well?
http://kbase.us/services/protein_structure_service
will make the changes, run my checks and then push to git and let you know right afterwards.
Thanks!
=sean
On Sat, Jul 12, 2014 at 9:03 AM, Thomas Brettin <[email protected]> wrote:
Hi Sean
Usually the deployment directory syntactically the same as the repo name. There are a few deviants from this, and its usually causes a bit of a hassle. Would you mind changing the deployment directory name to the name of the git repo?
Tom
On Jul 10, 2014, at 9:32 AM, Sean McCorkle <[email protected]> wrote:
Hello,
After some vetting by Shinjae last week, and a discussion with Dan yesterday, I would like to submit the KBase Protein Structure service that I've been working on as a candidate for production. The repo is "protein_structure_service" on git.kbase.us, the deployment target directory is "kbaseproteinstructure". There are two methods and two associated client scripts which give a est match PDB id given a KBase protein MD5 or feature id. I've done about as much as I can by way of documentation and testing. I sincerely hope this won't be a big hassle for anybody.
Looking forward to hearing from anybody on this, and thank you for the consideration!
Sean R. McCorkle [email protected] _______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
-- Sean R. McCorkle [email protected]
participants (1)
Sean McCorkle
