Re: [Release-team] Fwd: API doc for regprecise
I've redeployed this. It gets a startup error, which it seems to have always had.. It doesn't look like it affects deployment, but I'm going to bring it up with the owner. -- root@t21:~# ./deploy.rsc Service is regprecise No pid file /kb/deployment/services/cdmi_api/service.pid found for service cdmi_api No pid file /kb/deployment/services/idserver/service.pid found for service idserver Waiting for the domain to stop ..... Command stop-domain executed successfully. - Cloning dev_container - Cloning kb_seed - Cloning kbapi_common - Cloning typecomp - Cloning auth - Cloning idserver Running Make in dev_container Running Make deploy in dev_container ==== Deploying regprecise - Cloning regprecise * Using 20130213-test for regprecise - Processing dependencies for regprecise Starting bootstrap at /kb/dev_container Running make Running make deploy root@t21:~# There is a process already using the admin port 4848 -- it probably is another instance of a GlassFish server. Command start-domain failed. ----- Original Message -----
From: "Miriam L. Land" <[email protected]> To: "Nomi Harris" <[email protected]>, [email protected] Sent: Wednesday, February 13, 2013 10:29:48 AM Subject: Re: [Release-team] Fwd: API doc for regprecise
Nomi,
I've marked the spreadsheet for redeploy of regprecise.
Miriam
From: Nomi Harris <[email protected]<mailto:[email protected]>> Date: Wednesday, February 13, 2013 10:26 AM To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> Subject: [Release-team] Fwd: API doc for regprecise [was Re: Initial tech doc results for your module (Full Build, Feb 4, 2013)]
Dear Deploy team, Can you re-deploy regprecise? Thanks, Nomi
Begin forwarded message:
From: "Yoo, Shinjae" <[email protected]<mailto:[email protected]>> Subject: Re: API doc for regprecise [was Re: Initial tech doc results for your module (Full Build, Feb 4, 2013)] Date: February 13, 2013 12:51:00 AM PST To: Nomi Harris <[email protected]<mailto:[email protected]>> Cc: Pavel Novichkov <[email protected]<mailto:[email protected]>>
Nomi,
Your suggested changes is in place now:
root@ntest:/kb/dev_container/modules/regprecise# ls -al /kb/deployment/services/Regulation/webroot/ total 40 drwxr-xr-x 2 root root 4096 2013-02-13 08:48 . drwxr-xr-x 3 root root 4096 2013-02-13 08:48 .. -rw-r--r-- 1 root root 32716 2013-02-13 08:48 Regulation.html root@ntest:/kb/dev_container/modules/regprecise#
Please let me know if you have any other issues with Makefile.
Thanks, -SJ
On Feb 13, 2013, at 3:41 AM, Shinjae Yoo wrote:
Thanks Nomi,
Two things:
1) deploy-docs target fixed last week It seems the Makefile is old version
2) If you want just empty folder as web root, I can make changes to deploy-dir target to have empty webroot folder to copy it. I'll make this change now and test it on my test VM.
-SJ
On Feb 12, 2013, at 5:46 PM, Nomi Harris wrote:
(Sorry, forgot to cc you, Shinjae.) Nomi
From: Nomi Harris <[email protected]<mailto:[email protected]>> Subject: API doc for regprecise [was Re: Initial tech doc results for your module (Full Build, Feb 4, 2013)] Date: February 12, 2013 11:55:19 AM PST To: Pavel Novichkov <[email protected]<mailto:[email protected]>> Cc: "Tom S. Brettin" <[email protected]<mailto:[email protected]>>, Shane Canon <[email protected]<mailto:[email protected]>>, Nomi Harris <[email protected]<mailto:[email protected]>>
Hi Pavel, The "deploy-docs" target in your Makefile is still copying docs to the wrong directory; furthermore, by copying docs/*html it copies an index.html that is a Glassfish default page, which then hides the actual API doc (Regulation.html) from being visible in http://140.221.84.191/services/docs/Regulation/ . (If you look there now, you can see Regulation.html only because Shane manually moved index.html to index2.html.)
Your Makefile has: deploy-docs: build-docs cp docs/*.html $(TARGET)/services/$(SERVICE_NAME)/webroot/docroot/
It should say (I think--I did not actually test this): deploy-docs: build-docs mkdir -p $(TARGET)/services/$(SERVICE_NAME)/webroot cp docs/Regulation.html $(TARGET)/services/$(SERVICE_NAME)/webroot
Please let us know when you've made that change so we can redeploy regprecise and make sure the API doc ends up in the correct place so that we can clear your module for production release.
Thanks, Nomi
On Feb 5, 2013, at 9:44 AM, Nomi Harris <[email protected]<mailto:[email protected]>> wrote:
Dear KBase Module Owner,
Modules are required to have API docs deployed to the appropriate webroot directory in order to be included in the release. For this release, API docs should be visibile in http://140.221.84.191/services/docs/
If your module's Makefile conforms to the KBase standard Makefile, “make deploy” will have run “make deploy-docs”, which should make the html documents and copy them to webroot: ($(TARGET)/services/$(SERVICE)/webroot/ where $(TARGET) is typically /kb/deployment and $(SERVICE) is the name of your service--so, for example, /kb/deployment/services/idserver/webroot). These docs are normally generated from the comments in the typespec.
RESULTS OF TECH DOC CHECK (Full release, week of 2/4/2013) MODULE NAME: regprecise AUTHOR(S): [email protected]<mailto:[email protected]> DIRECTORY FOR API DOCS: http://140.221.84.191/services/docs/Regulation API DOCS PRESENT AT THAT URL? No--your "deploy-docs" target is copying the docs to the wrong directory. Please change to conform to the standard Makefile, https://git.kbase.us/dev_container.git/blob/HEAD:/doc/module.Makefile for more info. API DOCS COMPLETE? yes (but in wrong dir)
_______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
participants (1)
Dan Olson
