Re: [Release-team] Aug 2013 Build - Workspace service failed initial testing
Chris sent an email on 8/7 requesting that the workspace service be re-tagged and re-deployed. The oldest test tag in git is 20130806-test. Also, workspace is now dependent on: mssserver-url=http://biologin-4.mcs.anl.gov:7050 which is not a deployable kbase service. 1) retag, redeploy and retest as per chris's request 2) make msserver deployable in kbase. On Aug 8, 2013, at 8:07 AM, "Moulton, Steve" <[email protected]> wrote:
I'm on it.
-s
-- Steve Moulton UNIX/Linux Systems Engineer Cyber Operations & Research Integration (R&D Support), ITSD Oak Ridge National Laboratory Voice: 865-574-9609 Fax: 865-576-7605 moultonsa at ornl dot gov
-----Original Message----- From: Land, Miriam L. Sent: Thursday, August 08, 2013 8:37 AM To: Moulton, Steve; Dantong Yu; Dan Olson Cc: Thomas Brettin ([email protected]); Matt DeJongh; Christopher Henry Subject: Re: Aug 2013 Build - Workspace service failed initial testing
What does the deployment team think about this? The version on the test VM has passed testing.
Miriam
On 8/7/13 7:32 PM, "Christopher Henry" <[email protected]> wrote:
Can we update the workspace_service being deployed to the code I just committed to master (the latest master branch)? I just submitted a new function that allows us to pull multiple objects from the workspace at once. It's needed to clear up an outstanding ticket in JIRA. Tests all appear to be working.
On Aug 7, 2013, at 1:18 PM, Matt DeJongh <[email protected]> wrote:
I restarted the workspace_service and the tests all passed.
Matt
On Wed, Aug 7, 2013 at 12:35 PM, Matt DeJongh <[email protected]> wrote: I restarted the localhost mongod process and the server tests pass now.
Matt
On Tue, Aug 6, 2013 at 1:41 PM, Land, Miriam L. <[email protected]> wrote: Chris and Matt,
The module workspace service failed the Œmake test¹. It was run from the experiment VM on Magellan. You can replicate this by logging into the VM using:
ssh 140.221.84.191
sudo su
ssh <module_name>
source /kb/deployment/user-env.sh
cd /kb/dev_container/modules/<module_name>
This info is also given in https://trac.kbase.us/projects/kbase/wiki/TestingOverview. Some errors could be due to the configuration, the actual tests, or dependencies. Please work with the deployment team (Dan O., Dantong and Steve M.) if you believe that the problems are out of your control.
Warning: As root, you can make edits here but you will not be able to commit changes to the git repo.
Below is the error message that I got.
Miriam
Summary of workspace service
make test
../../tools/Makefile.common.rules:36: warning: overriding commands for target `deploy-libs'
Makefile:102: warning: ignoring old commands for target `deploy-libs'
for t in server-tests/workspaceServiceImpl.t ; do \
if [ -f $t ] ; then \
/kb/runtime/bin/prove $t ; \
if [ $? -ne 0 ] ; then \
exit 1 ; \
fi \
fi \
done
server-tests/workspaceServiceImpl.t .. ***Starting workspace service with mongo parameters:***
Host: localhost
Database: workspace_test
User:
Can't use string ("not master") as a HASH ref while "strict refs" in use at /kb/runtime/lib/perl5/site_perl/5.16.2/x86_64-linux/MongoDB/Collection.pm line 424.
server-tests/workspaceServiceImpl.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
No subtests run
Test Summary Report
server-tests/workspaceServiceImpl.t (Wstat: 65280 Tests: 0 Failed: 0)
Non-zero exit status: 255
Parse errors: No plan found in TAP output
Files=1, Tests=0, 3 wallclock secs ( 0.03 usr 0.01 sys + 0.46 cusr 0.12 csys = 0.62 CPU)
Result: FAIL
make: *** [test-service] Error 1
-- Matt DeJongh, Ph.D. Computer Science Department Hope College, Holland, MI 49423 (616) 395-7429
participants (1)
Thomas Brettin
