Re: [Release-team] communities_api failed script standard testing
Interesting- see below. These scripts were tested on the kbase test instance, and I'm not sure when bootstrap was last updated there... but this is probably low priority if everything else is working correctly. On Thu, Feb 6, 2014 at 10:59 AM, Travis Harrison <[email protected]> wrote:
For the first error you mentioned, your VM is too old or was not installed correctly. The error says that the python module scipy is missing, that module was added to the bootstrap repo on 2013-01-13.
For the second error, I fixed the bug and pushed the changes.
- Travis
On Thu, Feb 6, 2014 at 12:44 PM, Michael Sneddon <[email protected]>wrote:
Hi Andreas, Tobi, and Travis,
On testing for script standards, two scripts appear to be failing. It looks like communities_api is still set for production release, but you should probably be aware:
root@t1:~/msneddon-work/2013doctests/testing/script-tests# grep fail tests/communities_api.report.txt ----------TEST communities_api mg-inbox-decompress with -h option fail ----------TEST communities_api mg-inbox-decompress with --help option fail ----------TEST communities_api mg-correlate-metadata with -h option fail ----------TEST communities_api mg-correlate-metadata with --help option fail
root@t1:~/msneddon-work/2013doctests/testing/script-tests# mg-correlate-metadata -h Traceback (most recent call last): File "/kbase/deployments/20140109-prod//pybin/mg-correlate-metadata.py", line 9, in <module> from scipy import stats ImportError: No module named scipy
root@t1:~/msneddon-work/2013doctests/testing/script-tests# mg-inbox-decompress -h Global symbol "$input" requires explicit package name at /kbase/deployments/20140109-prod//plbin/mg-inbox-decompress.pl line 61. Execution of /kbase/deployments/20140109-prod//plbin/ mg-inbox-decompress.pl aborted due to compilation errors.
participants (1)
Michael Sneddon
