Re: [Release-team] Status of initial tech doc testing
Can someone on the sys admin team fix this? Thanks, Tom On Aug 7, 2013, at 6:58 PM, Michael Sneddon <[email protected]> wrote:
Nearly all of the services that have been deployed passed the initial doc testing.
The two exceptions are 'sim_service', which is not deploying API docs at all (needs to add the proper doc generation and deployment code to its Makefile), and 'search', which was deployed to a test VM that I couldn't find (not available from t1 by ssh search ??), and has no docs appearing here: http://140.221.84.191/services/docs/search/
In addition, several modules do have proper documentation that seems to be properly deployed, but is not appearing here: http://140.221.84.191/services/docs . It's probably just a proxy issue, but here is the list of those modules:
auth_service cluster_service expression KBaseFBAModeling plant_expression_service
_______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
participants (1)
Thomas Brettin
