Re: [Release-team] release process stuck on cbd
I'm not sure, you could try entering the ip address for production 140.221.43.50 into the deployment configuration. ----- Original Message -----
From: "Thomas Brettin" <[email protected]> To: "Dan Olson" <[email protected]> Cc: [email protected] Sent: Wednesday, September 25, 2013 10:01:56 AM Subject: Re: [Release-team] release process stuck on cbd
can we give them an IP address?
On Sep 25, 2013, at 10:01 AM, Dan Olson <[email protected]> wrote:
kbase.us doesn't make it out of the test environment. It is redirected based on the host name. There is no easy way around this.
If they have data that is necessary to build in the production shock - they will need to load this data into the test shock.
From: "Thomas Brettin" <[email protected]> To: [email protected] Sent: Wednesday, September 25, 2013 9:55:16 AM Subject: [Release-team] release process stuck on cbd
This is in the deploy team hands. It appears that a connection to kbase.us/services/shock-api/node is failing because.
Network controls needs to be investigated.
Can we get this one unstuck?
Thanks, Tom _______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
participants (1)
Dan Olson
