Re: [Release-team] Status of initial tech doc testing
On Aug 7, 2013, at 7:58 PM, Michael Sneddon <[email protected]> wrote:
Nearly all of the services that have been deployed passed the initial doc testing.
The two exceptions are 'sim_service', which is not deploying API docs at all (needs to add the proper doc generation and deployment code to its Makefile), and 'search', which was deployed to a test VM that I couldn't find (not available from t1 by ssh search ??), and has no docs appearing here: http://140.221.84.191/services/docs/search/
Bob fixed the Makefile and the API doc should appear when sim_service is redeployed.
In addition, several modules do have proper documentation that seems to be properly deployed, but is not appearing here: http://140.221.84.191/services/docs . It's probably just a proxy issue, but here is the list of those modules:
auth_service The doc now appears where it should but there is an extra self-referential webroot link in http://140.221.84.191/services/docs/authorization_server/ so that you can go to, for example, http://140.221.84.191/services/docs/authorization_server/webroot/webroot/web...
cluster_service Now ok
expression Almost: the doc is at http://140.221.84.191/services/docs/expression/webroot/ExpressionServices.ht... rather than http://140.221.84.191/services/docs/expression/ExpressionServices.html as it should.
KBaseFBAModeling Now ok, at http://140.221.84.191/services/docs/fbaModelServices/fbaModelServices.html
plant_expression_service Now ok at http://140.221.84.191/services/docs/PlantExpressionService/PlantExpressionSe...
participants (1)
Nomi Harris
