Re: [Mpi3-tools] Meaning of meaning of unique_id in mqs_communicator?
Ashley, In reading HP-MPI source code, which has implemented the MSQ interface quite a while back, I believe that we return a value which conforms to the definition (b) below. I'm not sure I understand the difference between (b) and (c). I hope this helps, Geoff Paulsen HP-MPI Regarding Ashley Pittman's message:
All,
I've raised this point before on the anl mpi-debugger mailing list however I'd still like resolution to the issue so I hope it's not in-appropriate to raise it again in this forum.
The problem I have is that when inspecting a parallel job in a debugger I find I'm unable to match communicators across MPI processes so it's impossible to tell which communicators in process A match which communicators in process B.
Each MPI process reports the existence of a number of communicators to the debugger and through the unique_id field of the mqs_communicator type it reports a ID for this communicator. It's the meaning of this ID which I'd like clarified.
There are three possible interpretations for this field.
(a) The ID could be unique to this process, typically a pointer to some internal struct.
(b) The ID could be unique to this process and also common to all members of the communicator, regardless of the MPI process on which they reside.
(c) The ID could be both unique to this process, common to all members of the communicator and also unique to this communicator.
Current MPI implementation's seem to favour (a) however this doesn't give the debugger enough information to match communicators in one process with communicators in a different process.
I believe the intention of the code when written was (b) and this does allow the debugger to match communicators across processes.
This issue presents me with real problems, I have a collective state inspection tool which is capable of detecting deadlock and spotting errant processes however without the ability to match communicators across processes it's functionality is severely crippled.
If possible could we discuss this on the call with a view to clarifying the current meaning and if necessary devising other means of exporting the required information.
Ashley Pittman,
_______________________________________________ Mpi3-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-tools
participants (1)
Geoffrey R. Paulsen
