Re: [Mpi3-tools] lightweight event log
Hi Martin,
Note, though, that you (as a tool writer) can always combine this logging interface with a PMPI logger and can grab any cleanly defined logging information from there as well.
Understood. What is still unclear to me, however, is how to incorporate the log information at runtime. Usually, I enter the wrapper create a timestamped enter-record, do whatever I want/need to do, call the PMPI call and create a timestamped exit-record. Now, in between I get another timestamped buffer that can only be interpreted later on? Then I could also just save the 'blob' with my trace and interpret the contents later on.
Yes, that is an option. During the pre-call wrapper, you can enable the fine grain logging and in the post-call wrapper you can then access the log buffer with all events that happened in between. Having an option at that time to save that buffer is a good idea, but would require the post processing tool to link against the same MPI on the same machine, since you will get only then the accessor functions that can interpret the buffer.
For a tool like ours it would not be a problem, as we distribute in source anyway, yet, I understand that this is not an option for every tool vendor. I think it should be doable, though, to have 'adapters' for a tool distributed in binary form, that is compiled at installation time, which does not contain any 'business logic' but just the interface to the MPI library.
I am not sure if it's worth having the user pick what should be recorded and what not, since this will be very limited anyway.
The user in this case is not necessarily the end-user but a tool. As you said above, a tool might want to combine these logs with the information gathered in a wrapper. The tool then might have an interest in defining a-priori what it wants to gather, to minimize overhead. However, you might be right that this flexibility might bear more overhead than a fixed set of predefined sets of logging variables.
This is a question for the MPI implementors about what they prefer or think is faster. It also depends on how many things/points an implementation will log. Basically it is a tradeoff between recording all information and testing which information should be recorded. I
I think anything that can be done to reduce trace size is worth to be discussed.
think some MPIs like MPICH already do something like this internally in debug builds, so it would be good to get some feedback from them on this issue.
Let's see what the discussion brings next time. I am still not sure whether I can make it to the next call. I have a workshop outside of Juelich on Monday till 5:30 PM CEST. I will try to get internet access and get out a little early to join in time, but I cannot promise anything at this moment.
Do I understand it correctly that the internal data should be converted on reading the buffer, or is a post-mortem interface possibly the better choice? This way any conversion can be delayed until we are no longer in measurement.
I think either way is fine. As mentioned above, we can add a mechanism to simply store the whole buffer in raw form into a buffer provided by the tool and then allow later inspection of it. However, as also said above, the tool will have to link against that particular MPI version on that particular platform to allow a correct interpretation of the data. This should be doable, though, at least for some post-processing converter.
What I didn't think of is that not all tools necessarily build against the MPI library. Thus you are right in that we might need both interfaces, one for the in-measurement conversion and one for post-mortem conversion. I think any post-processing conversion needs to be done on-the-fly by the tools to avoid re-writing the trace data. Best regards, Marc-Andre -- Marc-Andre Hermanns Juelich Supercomputing Centre Institute for Advanced Simulation Forschungszentrum Juelich GmbH D-52425 Juelich Germany Phone : +49-2461-61-2054 Fax : +49-2461-61-6656 eMail : [email protected] WWW : http://www.fz-juelich.de/jsc/ JSC is the coordinator of the John von Neumann Institute for Computing and member of the Gauss Centre for Supercomputing Sitz der Gesellschaft: Juelich Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498 Vorsitzende des Aufsichtsrats: MinDir'in Baerbel Brumme-Bothe Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender), Dr. Ulrich Krafft (stellv. Vorsitzender), Prof. Dr. Harald Bolt, Prof. Dr. Sebastian M. Schmidt
participants (1)
Marc-Andre Hermanns
