Re: [Mpi3-tools] New Version of MPI BoF Slides
Martin: Re:
It took me a while to get back to it, but here is a new version of the slides for the MPI BoF. Note that slides 3,5 and 6 are hidden and only for the web version.
I hope this includes most/all of the suggestions - let me know if you have any further comments (we need to wrap this up very soon, though).
The animated MPIT slide is good. I tweaked the animation slightly in the attached so that each examples text box appears just after the relevant animation. Also, I thought we agreed that we would not use hidden slides as it is confusing. In any event, I think you need some words on MPIT even with the animation. Further, the hidden MPIR texxt slide was almost identical to the unhidden one. I unhid all of the slides in the attached and merged the two MPIR text slides. A good tweak would be to animate the MPIR process figure but that would be above and beyond. Overall the current version does put us a couple slides over the request. However, it goes over due to the graphic slides, whichwill help to make the talk more interesting so I would hope that Rich would be OK with that. Bronis
participants (1)
Bronis R. de Supinski
