Re: [Mpi3-tools] MPIT 3.1: look up by name
Hi Bronis, all, We discussed this on the WG call today. I put the notes from the discussion on the wiki page. The gist of the conversation was that yes, it is a convenience function, but it may be worth having. The reason is that a tool can't simply iterate over the variables once and be done with it. The number of variables can increase at runtime, so a tool may have to iterate more than once. We settled on moving forward with a version of the routine that doesn't duplicate "get_info" but returns only the index and seeing how it plays out. Kathryn On May 2, 2013, at 6:19 AM, Bronis R. de Supinski <[email protected]> wrote:
I agree with Jeff that this request is a convenience function. Not only do I think he is right about it not needing to be performant and that an application could clearly do it itself but any more efficient implementation could be replicated at the application layer. For example, the tree-based approach could be done with one pass over the list that builds the tree.
On Thu, 2 May 2013, Jeff Squyres (jsquyres) wrote:
On May 1, 2013, at 1:06 AM, "Schulz, Martin" <[email protected]> wrote:
Is this just a convenience function?
An implementation could store all variables in a tree (or some other more efficient structure) eliminating the need for a loop in favor of a lower complexity lookup algorithm. How severe this problem is, is a different question.
I don't think that efficiency is the issue here -- even for an MPI implementation with thousands of cvars, a loop over them would take microseconds, at most. More specifically: I was not under the impression that cvar access needed to be performant.
I guess my point is that: regardless of mechanism, this functionality can definitely be implemented in the user application with the current MPIT APIs. Moving this functionality to *inside* MPIT is a convenience.
I'm not saying this is a good or bad idea -- I'm just making sure we all understand what is being asked. :-)
If we want to go for such a function, I wonder, though, if we should return all the arguments from GET_INFO or just the index (that you can then use get the rest of the information). This would could both keep the document (we are mentioning the GET_INFO functions a lot) and the implementations (only one pair of routines with such complex prototypes) simpler.
Martin
On Apr 30, 2013, at 2:39 PM, Kathryn Mohror <[email protected]> wrote:
Hi all,
I've started to work on 3.1 items. The first one is to allow the look up of variables by name instead of having to iterate through all variables until you find the one you want (assuming you know the name in advance). What do people think of this for supporting that functionality:
MPI_T_CVAR_GET_INFO_NAMED IN name OUT cvar_index OUT verbosity OUT datatype OUT enumtype OUT desc INOUT desc_len OUT bind OUT scope
MPI_T_CVAR_GET_INFO_NAMED behaves similarly to MPI_T_CVAR_GET_INFO except that the lookup is done by control variable name instead of its index. All restrictions and requirements for MPI_T_CVAR_GET_INFO are the same for MPI_GET_CVAR_INFO_NAMED except that the cvar_index is now returned from the function, and name is an input.
Then define MPI_T_PVAR_GET_INFO_NAMED in a similar fashion.
Thoughts? Objections?
Kathryn
______________________________________________________________ Kathryn Mohror, [email protected], http://people.llnl.gov/mohror1 CASC @ Lawrence Livermore National Laboratory, Livermore, CA, USA
_______________________________________________ Mpi3-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-tools
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Kathryn Mohror
