Re: [mpiwg-tools] Open MPI pvar scheme
On Nov 11, 2013, at 6:37 PM, "Schulz, Martin" <[email protected]> wrote:
Just to clarify: are you proposing that we add this officially to the standard (that particular naming scheme) or is this supposed to be an informal agreement?
The latter.
I personally would like to see the former, since it will be important to have something tools can rely on.
I think it would be better to programmatically express such relationships -- i.e., something new for MPI-4.
Assuming you meant that (that's how I understood it), here is one concern: this scheme is not very flexible - once a name is set and the enumeration variable is provided, this cannot be changed anymore. Isn't this even too restrictive for your case (where NICs can come and go in, e.g., a hot-pluggable system)?
Er... I don't understand. Why can't the enum strings change? I think they can change at any time. I think what you might be saying is that the *count* on a handle can't change -- right? I.e., MPI_T currently has no way of saying, "There were N values when you called pvar_handle_alloc() for this pvar, but now this pvar has M values." Right? If so, that's really a different (but still potentially valid) issue.
In general, the situation can appear in any scenario in which we have a variable that can (doesn't have to at the moment) return a value of more than 1 for the count. Depending on the variable, it can vary greatly in what that means and this can be very dynamic. I think a more dynamic lookup mechanism (e.g., query an enumeration once you have a count and a handle) would be better.
I don't think this is only for pvars with a count>1. What if N=1 and M=3 in the previous example? -- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
Jeff Squyres (jsquyres)
