[Mpi3-tools] Discussion Topics for the MPIT Interface
Hi all, As listed in the previous email, tomorrow's discussion will be around the MPIT interface. I am in the process of putting together a final proposal (based on the last version we had a while ago and the various additions and changes we discussed in the meantime). During this process, I came across a few open issues that I would like to get some feedback/discussion. Here is a list of issues (details below) that I would like to go through on the TelCon: - MPIT Session management - String interfaces and compatibility with rest of the standard - Use of handles for environment variables - Routines to control environment variables - How to integrate MPIT into the standard In particular the first two issues have quite an impact on the API and the MPIT document. it would be great if we could find consensus for them. If anyone has anything else, please send it out to the group. Thanks and talk to you on Monday, Martin MPIT Sessions --------------------- The current version of the MPIT interface is global, i.e., initialized once and all counters are set/reset globally. This works for one tool, but many said that this may not be sufficient. E.g., libraries may want to monitor some data, which would then conflict with other libraries or tools. We already adjusted the init and finalize routines such that they can be called multiple times, but that is only a partial solution. I think we need to keep this feature, though, but the question is whether we want to go beyond that. One idea was to have explicit session - instead of an init call, one would "create" an MPIT session and all subsequent calls to MPIT would take a session handle as the first argument. All counters allocated and probed during a session would then only be relative to the session in which they are called. This would certainly complicate the interface, but would also make it more general and more usable. Opinions? Does anyone see any obvious problems with going down this route? String Interfaces ---------------------- For many API calls, the MPIT interface relies on being able to return strings. The only other call (afaik) is MPI_Get_processor_name, which uses the following method: Define a constant for maximum string length OUT parameter for string buffer (written by the routine), which must be at least as large as the constant OUT parameter for the number of characters written by the routine In one of the presentations at the forum, some commented that this is not ideal since it can easily lead to buffer overflow. The suggested alternative was to include an IN parameter (or make the length an IN/OUT parameter) that allows the caller to specify how long the buffer is. If this is set to 0, the routine would not copy the string, but instead return the size of the string it intends to write. Tools can then allocate an appropriate size buffer. For MPIT this could be especially useful, since we intend to return description texts, which can be long. With this we have the following options (please add if there are more): - Stay compatible with the rest of the standard and use the techniques from MPI_Get_processor_name - Adopt the new interface for all MPIT calls only - Adopt the new interface for all MPIT calls and propose a new routine for MPI_Get_processor_name in MPI-3 with the new interface - Include both interfaces into MPIT (and propose a matching second routine for MPI_Get_processor_name) I personally think that we (for now) should stay away of changing MPI_Get_processor_name and hence would favor one of the first two solutions. Handles for Environment Variables ------------------------------------------------ Performance variables are accessed through handles to improve access speed. Initially we thought that we won't need this for environment variables, However, some have commented that this may also be useful and that we should add this. Are there any good use cases? If we decide to add this, should there be separate handles for performance and environment variables (since the query routines return significantly different information) or not (to reuse the actual data read and set routines)? Ability to Control Environment Variables ------------------------------------------------------ The API includes the ability to set environment variables (if the MPI library enables this). There is actually quite a bit of interest in this feature from the tools and application developer community (we had some discussions on this at SciDAC 2010). To make this more efficient, one suggestion was to allow "batch" updates - the idea behind this is that each single update may need global synchronization and/or may be costly. In this cases, the MPI implementation could delay the settings until an "apply call". One proposal for this would include: - Return information on whether a variable is delayed by MPI to a global apply call (as part of the query call) - A new API call, which is globally synchronizing (perhaps restricted to a communicator?), which then tries to apply all changes made since the last apply call. Variations are certainly possible. Question to the MPI implementors: would this be useful or do you not expect changes to environment to be costly/globally synchronizing? Integration into the standard -------------------------------------- Since we removed the debugging APIs from the proposal, we are proposing only one addition. We could do this one of two ways: - Add a new chapter just for MPIT - Create a shared chapter for tools (with PMPI and MPIT) I think, based on forum feedback, we still have a majority for the second option, which would also be my preference. Any other opinions on this? Decided Issues / pending integration into the document --------------------------------------------------------------------------- - Hierarchy and Group interface Proposed by Dave and discussed separately - Textual updates - Complete list of error codes / reorganization into a single table (there are probably more - don't have the full list in front of me at the moment) ________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Martin Schulz
