Re: [Mpi3-tools] Changes to the MPI_T*_ document
Martin: Re:
- Naming: People didn't like MPI_T_ and wanted something more expressive. MPI_Tool_ would be the obvious choice and that would be fine with me. Does anyone have a better suggestion? We can't spend more than four characters on it, though, or we will run into problems with the max. name size (even after shortening some names). Also, I would like this to be the final name change :).
I still feel that MPI_T is the best choice. No matter what prefix you choose, someone will not like it. [snip]
- We had some lengthy discussion on the thread and async signal safety. Below is a suggestion for a rewrite - once I get some feedback from our group, I will forward this to Brian, since he had the most issues with the current wording.
\begin{implementors} Sampling based tools rely on the ability to call the MPI tool information interface, in particular routines to start, stop, read, write and reset performance variables, from any program context, including asynchronous contexts such as signal handlers. MPI implementations should strive, if possible in their particular
OK through the above.
environment, to enable this behavior for all or a subset of the
Which "behavior"? You do not define any behavior above. You define support for usage scenarios. Change to: environment, to enable these usage scenarios for all or a subset of the
routines mentioned above. If implementing only a subset, the read, write, and reset routines are typically the most critical
for sampling based tools. If an MPI implementation is not able to provide such a behavior or if the behavior is only guaranteed under certain circumstances (e.g., for certain signals), this should be clearly documented, e.g., through the description return by {\mpifunc MPI\_T\_Get\_info}.
"such a"? UGH! Poor antecedent for "this". "return by"? Huh? change to: for sampling based tools. An MPI implementation should clearly document any restrictions on the program contexts in which the MPI tool information interface can be used. Restrictions might include guaranteeing usage outside of all signals or outside a specific set of signals. Any restrictions could be documented, for example, through the description returned by {\mpifunc MPI\_T\_Get\_info}.
\end{implementors}
Bronis
participants (1)
Bronis R. de Supinski
