Re: [mpiwg-tools] proposed text
Hi Kathryn, I think we don't have to search&replace the word string for <foo> string throughout the chapter. I think we only need to define <foo> string in 14.3.3 and then state for the 6 parameters so far that those are foo strings. By and large <foo> strings are just like other C string. We just have additional requirements to what "identical" means. That is why I came up with the name: "quasi-identical", because they are not identical in the normal C string sense (str*cmp). As "quasi-identical" is a new kind of string, that probably no-one heard in a different context, so has no preoccupation on what it could mean, a reader should go: "What's that?" and refer to Section 14.3.3. What's the groups take on the name "quasi-identical"? Should we have an "out-of-order" telco tomorrow to discuss this? As we need to finalize our wording by Monday in order for 383 to be an errata, I think we need to make progress before the weekend. Cheers, Marc-Andre PS: I know (almost) everyone is at SC, but maybe we can find a time for a call. On 18.11.14 22:03, Kathryn Mohror wrote:
I see what you mean, and that helps.
Do you think then, that all instances of the word "string" in this chapter (or the tools information interface part of the chapter anyway) need to be changed to "<foo> string"?
Or can we just say that we refer to them as <foo> strings wherever confusion might arise? (That seems a bit dangerous, I think, because who knows where confusion could arise for a particular reader?)
Kathryn _________________________________________________________________ Kathryn Mohror, [email protected], http://scalability.llnl.gov/ Scalability Team @ Lawrence Livermore National Laboratory, Livermore, CA, USA
On 11/18/14, 12:41 PM, "Marc-Andre Hermanns" <[email protected]> wrote:
Hi Kathryn,
if I understood right its a bit of both. We want to indicate that "our" strings (or their handling) are different from the rest of the standard, hence "MPI_T string" would be a good start. However, as I understand Jeff, it implies that "this is how MPI_T handles strings everywhere" and if we need some other handling of strings in MPI_T, we are then stuck with a name that implies the full scope of MPI_T when it does not provide it.
What about "quasi-identical" strings to explicitly name what we want to express. Something along the lines of:
Quasi-identical strings in MPI_T are strings that behave as if they are generated by a prefix-copy operation from a common source up to the length provided locally to the call returning the string.
With something like this, we could then say, "foo" is a quasi-identical strings as discussed in 14.3.3, wherever we need it, e.g., for name and desc in the respective calls.
What do you think?
Cheers, Marc-Andre
On 18.11.14 21:25, Kathryn Mohror wrote:
I'm a bit lost on the intended meaning behind the name: <foo> strings.
Do you want <foo> strings to indicate all strings in the MPI tool information interface that are by our definition in 14.3.3 treated differently than in the rest of the standard? And then have a concept of identical <foo> strings and specify what is returned in the user's buffer for identical <foo> strings?
Or is <foo> strings supposed to only indicate strings that if identical, have a particular defined behavior that determine what is returned into the user's buffer according to our string conventions in 14.3.3?
Thanks, Kathryn
- so up in 14.3.3, have a definition for "<foo> strings" (someone come up with a better name than "<foo>"):
MPI_T strings?
Mmm. That would imply that these are the *only* type of strings that are used in MPI_T. That may be true today, but I don't know if we want to be locked in to that generalization for forever.
How about "MPI_T universal strings"?
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ mpiwg-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-tools
-- Marc-Andre Hermanns Jülich Aachen Research Alliance, High Performance Computing (JARA-HPC) German Research School for Simulation Sciences GmbH
Schinkelstrasse 2 52062 Aachen Germany
Phone: +49 241 80 99753 Fax: +49 241 80 6 99753 www.grs-sim.de/parallel email: [email protected]
-- Marc-Andre Hermanns Jülich Aachen Research Alliance, High Performance Computing (JARA-HPC) German Research School for Simulation Sciences GmbH Schinkelstrasse 2 52062 Aachen Germany Phone: +49 241 80 99753 Fax: +49 241 80 6 99753 www.grs-sim.de/parallel email: [email protected]
participants (1)
Marc-Andre Hermanns
