Re: [Mpi3-tools] MPIT 3.1: look up by name
On May 1, 2013, at 1:06 AM, "Schulz, Martin" <[email protected]> wrote:
Is this just a convenience function?
An implementation could store all variables in a tree (or some other more efficient structure) eliminating the need for a loop in favor of a lower complexity lookup algorithm. How severe this problem is, is a different question.
I don't think that efficiency is the issue here -- even for an MPI implementation with thousands of cvars, a loop over them would take microseconds, at most. More specifically: I was not under the impression that cvar access needed to be performant. I guess my point is that: regardless of mechanism, this functionality can definitely be implemented in the user application with the current MPIT APIs. Moving this functionality to *inside* MPIT is a convenience. I'm not saying this is a good or bad idea -- I'm just making sure we all understand what is being asked. :-)
If we want to go for such a function, I wonder, though, if we should return all the arguments from GET_INFO or just the index (that you can then use get the rest of the information). This would could both keep the document (we are mentioning the GET_INFO functions a lot) and the implementations (only one pair of routines with such complex prototypes) simpler.
Martin
On Apr 30, 2013, at 2:39 PM, Kathryn Mohror <[email protected]> wrote:
Hi all,
I've started to work on 3.1 items. The first one is to allow the look up of variables by name instead of having to iterate through all variables until you find the one you want (assuming you know the name in advance). What do people think of this for supporting that functionality:
MPI_T_CVAR_GET_INFO_NAMED IN name OUT cvar_index OUT verbosity OUT datatype OUT enumtype OUT desc INOUT desc_len OUT bind OUT scope
MPI_T_CVAR_GET_INFO_NAMED behaves similarly to MPI_T_CVAR_GET_INFO except that the lookup is done by control variable name instead of its index. All restrictions and requirements for MPI_T_CVAR_GET_INFO are the same for MPI_GET_CVAR_INFO_NAMED except that the cvar_index is now returned from the function, and name is an input.
Then define MPI_T_PVAR_GET_INFO_NAMED in a similar fashion.
Thoughts? Objections?
Kathryn
______________________________________________________________ Kathryn Mohror, [email protected], http://people.llnl.gov/mohror1 CASC @ Lawrence Livermore National Laboratory, Livermore, CA, USA
_______________________________________________ Mpi3-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-tools
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Jeff Squyres (jsquyres)
