Re: [mpiwg-tools] MPI_T question about cvar value guarantees
Hi Jeff, That¹s a good question and I don¹t think we say - my original intent when writing the document (based on my personal model that I had in my head for this) was to provide no guarantees once MPI_T gets uninitialized, so in this case both versions would be OK. In fact, it could be even worse - what happens in case 1 if the component is not reloaded? Do you still have access to the variable at all? This is probably more likely if the MPI_T only block is after MPI_Finalize (since this would unload components), but the principle is the same. For the discovery/query routines we state that the numbering is not allowed to change between ³runs², which may have been the wrong thing to say - it probably should say ³while MPI_T is initialized². In this case, there would really not be any guarantees at all. If you wanted guarantees, you would have to keep MPI_T initialized. Martin On 2/4/16, 10:27 AM, "mpiwg-tools on behalf of Jeff Squyres (jsquyres)" <[email protected] on behalf of [email protected]> wrote:
Nathan Hjelm and I stumbled across a question regarding MPI_T today: what guarantees does MPI_T provide about control variable values when MPI_T is finalized and MPI is either not initialized or is finalized?
For example:
```C // Block A MPI_T_Init(...); MPI_T_Cvar_read(..., &value_pre); MPI_T_Cvar_write(...); MPI_T_Finalize(...);
// ...dead zone where neither MPI_T nor MPI are initialized...
// Block B MPI_Init(...) MPI_T_Init(...); MPI_T_Cvar_read(..., &value_post); assert(value_pre == value_post); ```
Is it guaranteed that the assert() in block B must be true?
Here's why I ask -- consider the following two scenarios:
SCENARIO 1: ===========
- Block A causes a dynamically-loaded component to be loaded and initialized - The cvar from that dynamically-loaded component is set to a default value - The cvar is then read into value_pre - The cvar is then assigned a non-default value - MPI_T is then finalized - Since MPI is not initialized, the dynamically-loaded component is unloaded (so that the process can be valgrind clean if it exits)
- Block B causes the same dynamically-loaded component to be loaded and initialized - The cvar from that dynamically-loaded component is set to a default value - The cvar is then read into value_post - value_pre and value_post are both the same (default) value -- the assert passes
SCENARIO 2: =========== - Block A causes a statically-loaded component to be initialized - The cvar from that statically-loaded component is set to a default value - The cvar is then read into value_pre - The cvar is then assigned a non-default value - MPI_T is then finalized - Since the component is static, it is *not* unloaded
- Block B causes nothing to happen to the component (because it's statically loaded) - The cvar from that statically-loaded component ***is still set to the non-default value*** - The cvar is then read into value_post - value_pre and value_post are different values -- the assert fails
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ mpiwg-tools mailing list [email protected] http://secure-web.cisco.com/1aYzk-C-pCKNMQorT9movJTtkDY_ZUa-l013Nc9x39G_dN 8qgUnFHdDDR2iuEiqxqpenHlCbnU-gvFtVLv6DIaANXPqZzyCRSClVaH6ZZEc0BjHPubzQKiTZ kShXPFRq7klwIdC3WFLfFFLsxo-2KCdhcWcWkw6hXAz_UqM7CQ12ys4IZabBMsdbIIFYesP_4o LNkoP_vmozJt34VHZrjefSoaEKvB-Gnfp9011IG_hOPlq75V_kNb5T820AfDVYFHQRnAeCsw-4 V_HqcX7AsIZEH1ura5UQdgP1Hba8zXL4aekNKNX9BfzgM1zVhVJGc87Esa5UDygPARLatnryLQ QpRzO4_m99ir8nC-C6zZY8/http%3A%2F%2Flists.mpi-forum.org%2Fmailman%2Flistin fo.cgi%2Fmpiwg-tools
participants (1)
Schulz, Martin
