Hi Jeff, On the being debugged issue, we had trouble finding the right text in the right changeset. On the mpi-forum issue #5 https://github.com/mpi-forum/mpi-issues/issues/5 which we use as the basis for the reading (right?), the text in the issue description and the provided PDF does not seem to fit to the pull request associated with it https://github.com/mpi-forum/mpir/pull/1/files Specifically, we are unable to find the new sentence: "If the variable exists in any MPI process, it is required that the variable is present in all MPI processes." Could you double check this? Also, something I just realized. Don't we have a "One line per sentence." convention for our LaTeX sources? This makes it easier to read changes within sentences. The pull request seems to have some form of line wrapping in place. Can we update this to the one-line-per-sentence convention? Cheers, Marc-Andre -- Marc-Andre Hermanns Jülich Aachen Research Alliance, High Performance Computing (JARA-HPC) Jülich Supercomputing Centre (JSC) Schinkelstrasse 2 52062 Aachen Germany Phone: +49 2461 61 2509 | +49 241 80 24381 Fax: +49 2461 80 6 99753 www.jara.org/jara-hpc email: [email protected]
participants (1)
Marc-Andre Hermanns
