Re: [mpiwg-tools] proposed text
Hi Kathryn, if I understood right its a bit of both. We want to indicate that "our" strings (or their handling) are different from the rest of the standard, hence "MPI_T string" would be a good start. However, as I understand Jeff, it implies that "this is how MPI_T handles strings everywhere" and if we need some other handling of strings in MPI_T, we are then stuck with a name that implies the full scope of MPI_T when it does not provide it. What about "quasi-identical" strings to explicitly name what we want to express. Something along the lines of: Quasi-identical strings in MPI_T are strings that behave as if they are generated by a prefix-copy operation from a common source up to the length provided locally to the call returning the string. With something like this, we could then say, "foo" is a quasi-identical strings as discussed in 14.3.3, wherever we need it, e.g., for name and desc in the respective calls. What do you think? Cheers, Marc-Andre On 18.11.14 21:25, Kathryn Mohror wrote:
I'm a bit lost on the intended meaning behind the name: <foo> strings.
Do you want <foo> strings to indicate all strings in the MPI tool information interface that are by our definition in 14.3.3 treated differently than in the rest of the standard? And then have a concept of identical <foo> strings and specify what is returned in the user's buffer for identical <foo> strings?
Or is <foo> strings supposed to only indicate strings that if identical, have a particular defined behavior that determine what is returned into the user's buffer according to our string conventions in 14.3.3?
Thanks, Kathryn
- so up in 14.3.3, have a definition for "<foo> strings" (someone come up with a better name than "<foo>"):
MPI_T strings?
Mmm. That would imply that these are the *only* type of strings that are used in MPI_T. That may be true today, but I don't know if we want to be locked in to that generalization for forever.
How about "MPI_T universal strings"?
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ mpiwg-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-tools
-- Marc-Andre Hermanns Jülich Aachen Research Alliance, High Performance Computing (JARA-HPC) German Research School for Simulation Sciences GmbH Schinkelstrasse 2 52062 Aachen Germany Phone: +49 241 80 99753 Fax: +49 241 80 6 99753 www.grs-sim.de/parallel email: [email protected]
participants (1)
Marc-Andre Hermanns
