Re: [mpiwg-tools] Ticket #383 -- Final text?
"sufficiently long enough" is redundant; "sufficiently long" is sufficient. On Mon, 19 May 2014, Jeff Squyres (jsquyres) wrote:
On May 18, 2014, at 2:35 AM, Martin Schulz <[email protected]> wrote:
Hi Kathryn, all,
A few comments: - "Adhere to the same definition from the MPI implementation.占쏙옙 - not sure what we meant with this anymore. Perhaps we should just drop this part.
What I meant by that is that each MPI implementation will create a definition for each cvar/pvar/etc. The implementation must adhere to that same definition in all connected processes. I.e., it can't change the definition of exactly what that variable is in different processes (e.g., bytes_in = bytes received from TCP in one process, but bytes received across shared memory in another process).
- "OUT index values占쏙옙 is not correct, since index values are IN parameters to the get_info calls. Perhaps just drop OUT?
Good catch; missed that. Yes, this whole clause can go.
- The mandate of equal OUT/INPUT values is also not quite right - for the strings, it占쏙옙s OK to return substrings of the size argument is too small. I know that占쏙옙s a technicality, but I am not sure if this causes problems later down the road.
Mmm. Good point. So the current text is:
* Return the same INOUT and OUT values from the relevant MPI_T_*_GET_INFO function.
(I took the liberty of dropping the index value clause)
I notice that we actually return 3 kinds of things from GET_INFO functions: integers/enums, strings, and MPI handles (i.e., MPI_Datatype). So how about this:
* Return the same INOUT and OUT integer and enum values from the relevant MPI_T_*_GET_INFO function. * If sufficiently long enough string length IN parameters are supplied, return the same string OUT parameters from the relevant MPI_T_*_GET_INFO function. * Return a handle to an equivalent MPI object from the relevant MPI_T_*_GET_INFO function.
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ mpiwg-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-tools
participants (1)
Bronis R. de Supinski
