Hi Martin, I see Rolf's point, although I am am unsure whether the initial wording of the change in 453 is correct. If you see it from the C perspective, declaration and definition are two separate things. However, the standard only talks about declaration of functions in the MPI_ namespace. That, IMHO, should never be allowed. What should be allowed is to "define already declared functions in the MPI_ namespace." I am unsure whether Fortran also has this distinction. C/C++ certainly has. If we now allow the _declaration_ of calls in the MPI_ namespace, then it would allow me to define MPI_Whatever(), which I think should still not be allowed. Off the cuff, I would try to find a wording that goes along the lines of: "... any redefined function in the MPI_ namespace must guarantee the semantics defined in the standard, but is allowed to have additional side effects". This is too rough cut, still. Yet, what I want to express is that any re-definition should not change the expected behavior of the call. Examples: - A non-blocking call should not suddenly block. - A blocking call must still ensure that the user buffer can safely be re-used after the call returns. - A broadcast should still be a call where the source of the data is the root and after completion all other processes have a copy of the root's buffer. (and not suddenly implement a reduce). This would still cover MPIEcho, because the additional MPI_Sends on the slave processes can be regarded as side effects, right?. The application still just sees the expected behavior of one message being sent from process to process. Cheers, Marc-Andre On 04.02.15 06:17, Schulz Martin wrote:
I am still not convinced we need this, but if we find the right language I am not opposed to it. Not sure, how we can write this the right way. This gets fuzzy very easily. Do you have a suggestion?
Martin
________________________________________________________________________ Martin Schulz, [email protected], http://scalability.llnl.gov/ CASC @ Lawrence Livermore National Laboratory, Livermore, USA
On 2/3/15, 8:37 AM, "Marc-Andre Hermanns" <[email protected]> wrote:
Dear all,
I just got a chance to talk to Rolf on this ticket: https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/358
The reason for this ticket was that in ticket 453 (https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/453), which passed as 3.0 errata, it is now explicitly allowed to declare functions in the MPI_ namespace, as long as the user wants to make use of the profiling interface.
The question now is, whether we should have a clarifying sentence in the profiling chapter to tell users of the interface not to tamper with the existing semantics of specific calls.
Rolf understood that the current wording in the ticket may be too ristrictive, as it remains unclear what 'fully conforms' still allows. His suggestion was maybe a less restrictive wording, where tools like MPIEcho are still allowed.
Cheers, Marc-Andre -- Marc-Andre Hermanns Jülich Aachen Research Alliance, High Performance Computing (JARA-HPC) German Research School for Simulation Sciences GmbH
Schinkelstrasse 2 52062 Aachen Germany
Phone: +49 241 80 99753 Fax: +49 241 80 6 99753 www.grs-sim.de/parallel email: [email protected]
_______________________________________________ mpiwg-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-tools
-- Marc-Andre Hermanns Jülich Aachen Research Alliance, High Performance Computing (JARA-HPC) German Research School for Simulation Sciences GmbH Schinkelstrasse 2 52062 Aachen Germany Phone: +49 241 80 99753 Fax: +49 241 80 6 99753 www.grs-sim.de/parallel email: [email protected]
participants (1)
Marc-Andre Hermanns
