[Mpi3-tools] MPIT chapter review
[Sorry it's taken me so long; as you might imagine, life at Sun, now a wholly owned subsidiary of Oracle, and soon to disappear as an independent company, has been "interesting."] I've reviewed it, and I've had two of our MPI folks, and one other tools person review it, too. The aggregated comments are below. Marty From Marty Itzkowitz: I dislike the use of the feminine pronouns by default. Either rewrite so that neither masculine nor feminine pronouns are needed, or always use "he or she", "his or her." p5, line 47. The meaning does not get more complex, the interpretation does. p22, line 7, reads better as "*safely *callable from *asynchronous* signal handlers to allow their use in sampling-based tools." From Terry Dontje: 1. What does MPIT_GET_SETINFO really do? I guess my problem is it takes a "set name" but where does one get the set name and how does that differ from the out parameter "name of the set". I read the section preceding the function description and I still just don't get it. 2. Seems like a lot of functions for the performance accessors. So to do the MPI state acquisition you will need to do the following: a. Loop on MPIT_PERFORMANCE_QUERY until you find the state performance variable. b. Call MPIT_PERFORMANCE_INFO with the state performance variable name to get the appropriate info you need (specifically datatype/count). c. Call MPIT_PERFORMANCE_GETHANDLE on the state performance variable name. d. Call MPIT_PERFORMANCE_START on the state performance handle to activate the use of the state code. e. Periodically call MPIT_PERFORMANCE_READ using the state performance handle while the MPI code is running f. Once the MPI code finishes call MPIT_PERFORMANCE_FREEHANDLE I guess it isn't that bad we're just adding 4 additional calls which are necessary in order to have more than one performance variable. Just seems like a lot on paper (in the spec). From Eugene Loh: Have the MPIT interfaces been prototyped by anyone? [Yukon Maruyama asked the same question. None of us feels confident we can understand the issues before we see a prototype.] Since the returned information is so implementation-dependent, it's hard for me to imagine that there could be (m)any MPIT-based tools that make sense for multiple MPI implementations. Meanwhile, if a tool makes sense for only one MPI implementation, it should be part of the implementation itself. In general, I'm still scratching my head over this MPIT stuff. And some nits: page 6, line 47: All identifier covered by this interface carry -> All identifiers covered by this interface carry page 7, line 1: all conventions and principle governing -> all conventions and principles governing page 7, line 33: must contain exactly one call to the MPIT initialization routine -> must execute exactly one call to the MPIT initialization routine page 8, lines 17 and 26: before MPIT_INIT and after MPIT_FINALIZE -> before MPIT_INIT or after MPIT_FINALIZE page 12, line 42: The table of legal "scope" values seems to be misplaced to the top of page 13. page 12, line 44: it is not a guarantee that can be changed. Is there a typo in that line? [Marty] I'm not quite sure what this line is saying. Does it mean that even if the scope says that a variable is changeable, the call to change it is not guaranteed to succeed? If that's so, what can the tool implementor rely on?
participants (1)
Marty.Itzkowitz@Sun.COM
