Re: [mpiwg-sessions] Virtual MPI forum meeting June 7, 2023 / Vote announcement for the July 2023 meeting of the MPI Forum
On Jun 8, 2023, at 10:15, Holmes, Daniel John via mpiwg-sessions <[email protected]> wrote:
Hi Howard (& all),
In the MPI Virtual meeting yesterday, Rolf presented a PR that tries to define the word "pending" in MPI. The discussion raised a whole bunch of issues and concerns. I took an action to raise some of them in the Sessions WG because they are introduced by (or made worse by) the sessions model.
Quick summary of options in Rolf's proposal: 1) Remove the word "pending" from the MPI Standard -- replace it with "active" where that makes sense, or something else when appropriate. 2) Define "pending" to be a strict alias of "active" -- it can only be applied to MPI operations and it means "starting stage has been done but completion stage has not yet been done" 2) Define "pending" to be anything task/activity on MPI 's to-do list -- encompassing all active operations but also all decoupled activities (i.e. progress).
We discovered in the discussion of these options, in the context of MPI_FINALIZE and MPI_DISCONNECT (which must delay their return until "pending" things have been done) that an important restriction has been unintentionally removed by the introduction of sessions and we probably need to re-introduce parts of that restriction.
When there was only the World Model, it was erroneous to call things like MPI_REQUEST_FREE after MPI_FINALIZE. Questions like "can I free a request after finalize?" -- derived from questions like "what happens to inactive persistent requests when I finalize MPI?" -- made no sense because you can look at the code with MPI_REQUEST_FREE after MPI_FINALIZE and immediate declare it is an erroneous program.
Once sessions came into existence though, we can now call MPI_REQUEST_FREE after MPI_FINALIZE, as long as there is a session:
``` MPI_SESSION_INIT(&sh) MPI_INIT() MPI_RECV_INIT(..., MPI_COMM_WORLD, &req) MPI_FINALIZE() MPI_REQUEST_FREE(&req) MPI_SESSION_FINALIZE() ```
This is clearly A Bad Idea (tm), but which MPI rule has been broken in the above pseudo-code? Without the two sessions lines of code, this is clearly erroneous, but with them it is not. Do we want this pattern to be erroneous or well-defined?
I think that example is still erroneous, because the request is posted on the WPM; there is some catchall text that makes not calling all procedures on WPM objects to complete them before calling MPI_FINALIZE erroneous code. If the current text doesn’t clearly says so (the completion criterion that everything should be inactive implies it for WAIT, etc, not as clearly for FREE on inactive persistent reqs), we should amend text so that it precludes using procedures on WPM handles after MPI_FINALIZE. However the same example with a request posted on the SPM, and calling free after SESSION_FINALIZE would be valid. As you say later in your essay, we have to choose if we want it to remain so, or if we want to errata this behavior out of existence. The SPM implementations do not support this, so there is no real backward incompatibility to be worried about when declaring this retro-actively that it was always erroneous.
There is no semantic reason why this cannot be deemed legal -- MPI_REQUEST_FREE is a local procedure, so the fact MPI_COMM_WORLD is no longer functional should be irrelevant -- it could just clean up locally allocated resources (the connections to other processes were cleaned up during MPI_FINALIZE).
One technical reason to define this pattern to be erroneous is that the request probably has a ref-counted reference to the communicator and MPI_FINALIZE will hang waiting for that ref-count to reach zero, which it cannot do because the request will not be freed until after it returns. This is an implementation detail, but it is how at least one major MPI library is currently implemented.
An implementation could instead choose to store a weak_ptr (https://en.cppreference.com/w/cpp/memory/weak_ptr) to the communicator in the request when the operation is inactive, attempt to get a shared_ptr from the weak_ptr (https://en.cppreference.com/w/cpp/memory/weak_ptr/lock) during the starting stage, and give up the shared_ptr during the completion stage. In such an implementation, an inactive request does not own the communicator associated with the operation, so finalize can destroy the communicator, and a freeing an inactive request never needs to dereference to get the communicator, so it doesn't care whether the communicator still exists or not.
Much more important than technical feasibility is the question "why should we enable this pattern?" mumble mumble C++ destructors mumble garbage collected languages mumble.
Taking a step back, there is a whole category of programs that used to be erroneous by definition (cannot make MPI calls after MPI_FINALIZE) that are no longer obviously erroneous. What do we do about them all?
There are related issues/concerns here: if a rule is added to MPI that forces MPI_FINALIZE to free all requests associated with the World Model, should sessions follow suit and have MPI_SESSION_FINALIZE free requests from that session? There is text exhorting the user to enable and complete all MPI operations (in the World Mode) before calling MPI_FINALIZE, but there is no such exhortation for the sessions model; should there be one? Does finalizing a session destroy all the communicators from that session? Can a communicator handle be used after the session is finalized (e.g. in MPI_COMM_FREE)?
Not pushing in any particular direction here, just exposing some pros-cons: For the sake of uniformity, it would be desired that all of these FINALIZE/DISCONNECT procedures have a similar behavior, since they kind-of do the same thing in different contexts. This also has advantages in terms of implementation simplicity. However, one may consider the following example and want this to be valid code: ``` MPI_SESSION_INIT(&sh) MPI_COMM_CREATE_FROM_PSET(comm,...) MPI_SESSION_FINALIZE(&sh) MPI_SEND(comm); MPI_RECV(comm) MPI_COMM_DISCONNECT(comm) ``` Since the body of the application does not need to use session objects anymore after CREATE_FROM_PSET, users may be interested in closing the session immediately (which can obviously be done at that point, since no communications are pending when we close it, and they use disconnect to prevent straggling buffered message to linger in limbo when freeing the comm). We even had a discussion about having SESSION_FINALIZE_LOCAL at some point, presumably a good tool to support this. A disadvantage is obviously that we cannot assert that the library is valgrind-clean at SESSION_FINALIZE point, since a bunch of MPI objects have to remain allocated/refcounted for this to work. ~~~ One oblique consideration in that decision about uniformity is that we have the same problem for MPI_COMM_DISCONNECT, and that has existed for a sufficiently long time that it may not be as easy to just errata it out of existence in that case (I don’t think people are generally using DISCONNECT a lot to start with, and implementation review may reveal that problematic usage patterns never worked in practice, which would then open the way for the errata approach in the COMM_DISCONNECT case). Aurelien
Best wishes, Dan.
-----Original Message----- From: Rolf Rabenseifner <[email protected]> Sent: Wednesday, June 7, 2023 6:10 PM To: Holmes, Daniel John <[email protected]> Subject: Fwd: Virtual MPI forum meeting June 7, 2023 / Vote announcement for the July 2023 meeting of the MPI Forum
The pdf is https://github.com/mpi-forum/mpi-standard/files/11676448/mpi41-report_Issue7... especially the questions on page 482 and 524.
----- Forwarded Message ----- From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Wednesday, June 7, 2023 1:51:04 PM Subject: Re: Virtual MPI forum meeting June 7, 2023 / Vote announcement for the July 2023 meeting of the MPI Forum
Dear MPI forum members,
last update for #710/PR823: second option (alternative B) and open questions for MPI_Session_finalize, see https://github.com/mpi-forum/mpi-standard/files/11676448/mpi41-report_Issue7... for the virtual meeting today.
Kind regards Rolf
________ email from yesterday: _________
for the virtual meeting this week (June 7, 2023) the following readings and discussions are scheduled. Some technical decisions are needed and it may be best to do these decisions as institutional staw votes in an additional virtual meeting (e.g. next week), rather to do them ad hoc this week.
The topics are #705/PR822, #710/PR823 with two options, #676/PR824 or PR825.
Details: __________________________ #705 Errata: Fortran has only compile-time constants Rolf,Joseph Issue https://github.com/mpi-forum/mpi-issues/issues/705 (together with https://github.com/mpi-forum/mpi-issues/issues/657 Rolf, Jeff H.) PR https://github.com/mpi-forum/mpi-standard/pull/822 PDF https://github.com/mpi-forum/mpi-standard/files/11450065/mpi41-report_Issue7...
This proposal seems to be already stable.
__________________________ #710 Errata: 'Pending communication' not defined in MPI_Comm_disconnect Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/710 PR https://github.com/mpi-forum/mpi-standard/pull/823 updated: PDF https://github.com/mpi-forum/mpi-standard/files/11676448/mpi41-report_Issue7...
There is severe critism about the current proposal in PR 823:
"In this PR here, as far as I can see, the implementations are mainly affected if they incorrectly require that there must not be any inactive request handle using the given comm. Whether an MPI lib really internally frees the inactive handles or not, is mainly a question of having dangling handles or not." "Is there broad agreement that this is incorrect implementation behavior? I'm skeptical."
And therefore, there are two different solutions: - An advice to users, telling the consequences if they do not free inactive handles before calling MPI_Comm_disconnect or MPI_Session_finalize. or - Automatically freeing them.
And furthermore:
"Whatever we decide, I imagine this needs to extend to MPI_SESSION_FINALIZE as well."
I'll try to update the proposal before the meeting to have text for both possible solutions.
__________________________ #676 Errata: 'Pending operation' not defined, pending proper definition Rolf,Joseph Issue https://github.com/mpi-forum/mpi-issues/issues/676 PR https://github.com/mpi-forum/mpi-standard/pull/824 PDF https://github.com/mpi-forum/mpi-standard/files/11668075/mpi41-report_Issue6...
Substituting "pending operation" by "active operation"
or PR https://github.com/mpi-forum/mpi-standard/pull/825 PDF https://github.com/mpi-forum/mpi-standard/files/11669354/mpi41-report_Issue6...
Defining "pending operation" as "active operation" (see page 12)
Best regards Rolf
----- Original Message -----
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Christoph Niethammer" <[email protected]>, "Puri Bangalore" <[email protected]>, "Joseph Schuchart" <[email protected]> Sent: Wednesday, May 24, 2023 1:36:42 PM Subject: Re: Update: Vote announcement for the July 2023 meeting of the MPI Forum
Martin, Wes, and all,
I expect that we should reserve also June 14, 2023 for a possible continuation of open questions resulting from the discussions of
#705/PR822, #710/PR823, and #676/PR824 are now finalized at least for the virtual forum meeting, June 7, 2023
and other pending items for MPI-4.1 from the June 7 virtual forum meeting.
Best regards Rolf
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Christoph Niethammer" <[email protected]>, "Puri Bangalore" <[email protected]>, "Joseph Schuchart" <[email protected]> Sent: Thursday, May 11, 2023 8:05:07 PM Subject: Update: Vote announcement for the July 2023 meeting of the MPI Forum
Dear forum members,
#705/PR822, #710/PR823, and #676/PR824 are now finalized at least for the virtual forum meeting, June 7, 2023, details below:
https://github.com/mpi-forum/mpi-standard/files/11450065/mpi41-report _Issue705%2B657_PR822.pdf
#710 Errata: 'Pending communication' not defined in MPI_Comm_disconnect Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/710 PR https://github.com/mpi-forum/mpi-standard/pull/823 PDF
https://github.com/mpi-forum/mpi-standard/files/11454896/mpi41-report _Issue710_PR823.pdf
https://github.com/mpi-forum/mpi-standard/files/11443976/mpi41-report _Issue676_PR824.pdf
The agenda of the virtual meeting should be reading and discussions if needed. I did the proposals based on the discussion and the major goals: - backward compatible, - no performance drawbacks on critical paths, - full consistency of the solution with all related parts of the MPI standard.
If I have overseen something, then my apologies.
If somebody wants to provide a completely different solution to one of these issues, please feel free to do it. - Thanks to Joseph who did PR 822, which was such a counter proposal for #705. - This method is often better than doing many change requests for the given PR. and it helps to completely check whether it is really consistent over all related parts of the MPI standard. - And thanks for all the comments so far. They really helped me a lot for preparing the three PRs.
I'll be the next three weeks on vacation.
Best regards Rolf Rabenseifner
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Christoph Niethammer" <[email protected]>, "Puri Bangalore" <[email protected]>, "Joseph Schuchart" <[email protected]> Sent: Tuesday, May 9, 2023 6:07:04 PM Subject: Vote announcement for the July 2023 meeting of the MPI Forum
Dear forum members, (correction: it is for the July 2023 meeting)
I would like to make the following announcements for the next MPI Forum Meeting (July 10-13, 2023):
- 2nd votes on #669 Add operation state 'enabled' and 'local calls' into Terms Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/669 PR https://github.com/mpi-forum/mpi-standard/pull/788
#457 Improvements around the word "rank" in the Process Topologies chapter Christoph,Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/457 PR https://github.com/mpi-forum/mpi-standard/pull/804
#485 Fix Incorrect Usage of Rank/Task/etc. in Language Bindings Chapter Rolf,Puri Issue https://github.com/mpi-forum/mpi-issues/issues/485 PR https://github.com/mpi-forum/mpi-standard/pull/803 PDF
https://github.com/mpi-forum/mpi-standard/files/10831598/mpi41-repor t_Issue485_PR803.pdf
- errata reading and vote on
#679 Errata: Noncollective (for procedure) and nonpersistent are not defined Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/679 PR https://github.com/mpi-forum/mpi-standard/pull/820 PDF
https://github.com/mpi-forum/mpi-standard/files/11432286/mpi41-repor t_Issue679_PR820.pdf
- pre-announcement for errata reading and vote on --> See also virtual meeting, June 7, 2023 !!!
-- Dr. Rolf Rabenseifner . . . . . . . . . .. . . [email protected] . High Performance Computing Center (HLRS) . . . ++49(0)711/685-65530 . University of Stuttgart . . . . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, 70569 Stuttgart, Germany -- Dr. Rolf Rabenseifner . . . . . . . . . .. . . [email protected] . High Performance Computing Center (HLRS) . . . ++49(0)711/685-65530 . University of Stuttgart . . . . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, 70569 Stuttgart, Germany _______________________________________________ mpiwg-sessions mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-sessions
participants (1)
Aurelien Bouteiller
