Re: [mpiwg-sessions] [Mpi-forum] problems pushing to your fork of mpi-standard
Dear Howard and all, it took longer, but done: - PR 547 - https://github.com/mpi-forum/mpi-standard/pull/547 includes exactly the solution from https://github.com/mpiwg-sessions/mpi-standard/pull/48/files - plus a few request for better wording/formatting from Dan in the example - plus an unresolved formatting change from mainly implemented (therefore obsolete) PR 519 - plus a few ideas from Dan that I would reject (see my comments), - plus the pdf (see pages 502+503): https://github.com/mpi-forum/mpi-issues/files/6043469/mpi40-issue435-PR547-s... Dan, I hope it is okay that I close these additional comments in the PR before the meeting starts that Howard can present a clean and in my eyes now really perfect solution for the problem raised in https://github.com/mpi-forum/mpi-issues/issues/435 Best regards Rolf ----- Original Message -----
From: "Rolf Rabenseifner" <[email protected]> To: "mpiwg-sessions" <[email protected]> Cc: "Pritchard" <[email protected]>, "Wesley Bland" <[email protected]> Sent: Thursday, February 25, 2021 11:05:07 AM Subject: Re: [Mpi-forum] problems pushing to your fork of mpi-standard
Dear Howard, Wesley and all,
Could others check this?
I'll take (in about 1h) the current text in https://github.com/mpiwg-sessions/mpi-standard/pull/48/files and produce a PR for MPI-4 that - we have also an officially produced pdf from that, - you can read it today from file changes and pdf.
Then all is prepared for today.
Import is also to read the other ticket with minor changes that all will be a normal erata-style-vote in next meeting, and not a non-no-vote thing.
Best regards Rolf
From: "Main MPI Forum mailing list" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Pritchard" <[email protected]> Sent: Wednesday, February 24, 2021 8:44:25 PM Subject: [Mpi-forum] problems pushing to your fork of mpi-standard
Hi Folks,
I think we’ve run over some GitHub private repo limits. Neither Dan nor I can push/pull to/from either our mpiwg-sessions fork of the mpi-standard or forks into our personnel projects spaces.
We recently invited another member to our WG sessions Github group and are suspicious we’ve gone over some kind of limit.
Wesley could you check this out?
At this point I can no longer update my PRs against the mpi-standard since I can’t push to my fork of the mpi-standard.
Howard
Howard Pritchard
HPC-ENV
Los Alamos National Laboratory
_______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) .
participants (1)
Rolf Rabenseifner
