Re: [Mpi3-rma] MPI-3.1 consideration slides
The change suggested on slide 2 is not right. In the existing standard, for the separate memory model, the restriction is that a put/accumulate must not access a target window once a local update (to anywhere in the window) has started or a put/get (to *overlapping memory locations* in the window) has started. You are allowed to do concurrent put/gets to distinct memory locations in the same window. So the change needed is say "put/get to overlapping memory locations" instead of "put/get to an overlapping window". Rajeev On Dec 1, 2012, at 8:21 PM, Pavan Balaji wrote:
All,
Please see the attached slides as consideration items for MPI-3.1.
-- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji <mpi31-rma.pptx>_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Rajeev Thakur
