Re: [Mpi3-rma] Memory barriers in MPI_WIN_LOCK_ALL mode
On Tue, Oct 30, 2012 at 08:48:47AM -0500, Pavan Balaji wrote:
On 10/30/2012 07:28 AM, Torsten Hoefler wrote:
If the MPI_GET on P1 does a local load operation internally, it is not memory consistent without a memory barrier. Does this mean that I need to always do a memory barrier on all local GET operations to get the right value? Well, if the put came from shared memory, then the flush would most likely do a memory barrier (depending on the consistency model of the architecture, i.e., in TSO (x86) it would need an mfence). If the put came from remote memory then there should not be a problem because the flush must block until the data is visible to the CPU (assuming the unified memory model, if you were in separate, you'd need an additional win_synch).
Actually, the flush only needs to block till its visible to another MPI RMA operation, not to the CPU (as in, not to load/store).
In the unified memory model, it has to guarantee visibility to load/store operations as well.
I don't think the target process can guarantee that the PUT is visible to a load/store without an additional memory barrier. The flush of the source process has to ensure that.
Since in the MPI standard, we don't specify that the user needs to call a WIN_SYNC in this case, I'm asking if the MPI implementation needs to do a memory barrier internally. Yes, win_synch is only needed in the separate model, which would then do a memory barrier. The MPI library has to guarantee that there is no inconsistency between public and private copy in the unified model (or it cannot claim that it supports unified).
Note that this is likely only a theoretical exercise, since most (all?) compilers will do a memory barrier anyway if they see a function call (MPI_GET in this case). But is MPI assuming that that's going to be the case for efficient execution? Really? Which compiler puts a memory barrier before function calls? This sounds rather inefficient to me (in the days of fastcall).
Sorry, I meant it'll not reorder operations across function calls, rather than a memory barrier. Ah, right!
Best, Torsten -- ### qreharg rug ebs fv crryF ------------- http://www.unixer.de/ ----- Torsten Hoefler | Assistant Professor Dept. of Computer Science | ETH Z�rich Universit�tsstrasse 6 | Zurich-8092, Switzerland CAB E 64.1 | Phone: +41 76 309 79 29
participants (1)
Torsten Hoefler
