Re: [Mpi3-rma] RMA proposal 1 update
I am one of the DCMF developers that wrote the low-level implementation for the various one-sided operations on BG/P and I've also done some work with implementing ARMCI over DCMF on BG/P. I have some general comments, but can't really find an appropriate email to 'reply to' .. so I'll just dive in here. I think the discussion of the three possible implementations below misses the mark a bit. Any low level messaging layer (DCMF, LAPI, even "MPI") that can optimize the allreduce and barrier operations could implement the allfenceall operation as described below. Even though DCMF - which what MPICH2 on BG/P is based on - uses the BG/P collective network, it still is *only* a fast allreduce that has benefits over other pt2pt allreduce algorithms and not very interesting when considering how an allfenceall would be implemented. If we look at any exascale goal(s), as Jeff mentioned earlier, we'll see that any time an application or middleware needs to track counters we won't get the scaling required (assuming the allfenceall is flexible and not restricted to only "comm_world" operations). What is needed is an interface that allows low level software to take advantage of any hardware or network features that would enable a "counter-less" allfenceall implementation. On BG/P, this would probably take advantage of features such as the torus dimensions of the network, the (configurable) deterministic packet routing, the "deposit bit" in the packet header, etc. I'm not saying I have any specific design in mind, just that experience tells me that we should be able to do something cool in this space supported by the BG hardware which would eliminate the need for software accounting. If there was an allfenceall interface, then low level message could do whatever it takes to get performance and scaling. Without the allfenceall interface middleware is forced to use one of these platform independent algorithms (allreduce, barrier, etc) and accept any inherent scaling and performance restrictions. Michael Blocksome Blue Gene Messaging Advanced Systems Software Development [email protected] From: Jeff Hammond <[email protected]> To: "MPI 3.0 Remote Memory Access working group" <[email protected]> Date: 05/21/2010 05:13 PM Subject: Re: [Mpi3-rma] RMA proposal 1 update
I've been talking about allflushall because ARMCI_Barrier is partially redundant with MPI_Barrier, which is clearly already in MPI-3.
Intuitively named as ARMCI_Barrier - I imagine why I missed that ;-) So, this offers some opportunity for experimentation... ARMCI_Barrier should be what GA_Sync calls, right? How is the implementation of ARMCI_Barrier done on BG? It would seem that we could try 3 implementations in some real world usage scenarios and get some data:
Yes, and not to be confused with armci_msg_barrier (<http://www.emsl.pnl.gov/docs/parsoft/armci/documentation.htm#collect>) :(
1) ARMCI_Barrier the "really bad" way: i.e. np^2 messages get generated and then a barrier is done 2) ARMCI_Barrier as a collective: allreduce is used to agree about completion 3) ARMCI_Barrier assuming a "small" number of targets between barriers/fences: you track who has outstanding messages and only sync with them.
Yeah, I'm going to work on this as soon as I have some free time. I have (1) and (3) already but I need to test them outside of NWChem to have any hope of making sense of the data. I think I can at least hack (2). I think I can implement a fourth option that beats (2) but it has the same complexity model (logarithmic).
Anyway, just to clarify, GA regularly uses both one-sided and collective completion calls? Or, is it dominated by one or the other? I look at GA_Fence() and see the equivalent of flushall() and GA_Sync = GA_Fence() + MPI_Barrier(). If you call both, then you have this mixture of passive and active target, but... if GA_Sync is going to perform significantly better than GA_Fence(), couldn't you just switch to calling GA_Sync? It would seem like users would rather have the barrier too (especially if it was cheaper than calling GA_Fence()). Or, put another way, the online guide for GA essentially says "um, don't call GA_Sync() very often", so is allfenceall optimizing the infrequent case?
The GA manual can say that calling GA_Sync will bring on the apocalypse, but that won't stop quantum chemistry software developers from calling it at the top and bottom of every subroutine. =O While there are too many GA_Sync calls in NWChem, removing the majority of them requires a complete rewrite of very complex algorithms and problem redesigning the entire code from top to bottom. I have never seen GA_Fence used. All ~remote~ completion in NWChem is collective. All three modes of local completion - trivial (blocking), individual (request-based) and bulk (fenced target) are all used explicitly via GA or implicitly within GA but invisible to the GA user. GA_Fence was probably added much later in response to NWChem users, so it isn't surprising it is never called in NWChem except in a "test all GA functionality" utility routine.
UPC has a similar scenario: barrier implies a strict access that causes a flushall, but everybody knows that you avoid calling barrier to the extent you possibly can. So, the model you use is actually focused on minimizing either strict accesses or barriers, but you would typically rather do a strict access than a barrier. If GA code is optimized the same way, how often is GA_Sync() called?
GA_Sync is called like crazy in NWChem. There is an effort to fix this pathological behavior in one particularly heinous abuser (TCE) but it will be a long time before NWChem learns to be kind to network hardware. Jeff -- Jeff Hammond Argonne Leadership Computing Facility [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Michael Blocksome
