Re: [Mpi3-rma] Next RMA Telecon
26 Dec
26 Dec
'11
8:40 p.m.
On 12/26/2011 12:12 PM, Torsten Hoefler wrote: > On Mon, Dec 26, 2011 at 12:22:38AM -0600, Pavan Balaji wrote: >> >> On 12/09/2011 03:36 PM, Torsten Hoefler wrote: >>>> 3) allocate_shared proposal with MPI_Win_lock_all(exclusive) >>> - remove MPI_Win_lock_all(exclusive) from the proposal and re-read >> >> Why was this removed? > Brian and others felt that an implementation on a distributed-memory > network would put a huge burden on the implementers and may cause other > problems. A workaround offering essentially the same functionality by > using point-to-point and collective synchronization (i.e., block p-1 > processes in a barrier while one process updates the shared memory) was > identified. Didn't we already discuss this in one of the working groups (though I forget whether it was RMA or hybrid)? If I recall correctly, a non-RMA solution was shot down because it doesn't provide the memory barriers that a lock/unlock would do. Someone also pointed out that we could do a for loop of Win_lock(exclusive) to achieve the same result, but it was not scalable. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
5322
Age (days ago)
5322
Last active (days ago)
0 comments
1 participants
participants (1)
Pavan Balaji
