Re: [Mpi3-rma] notes from 5pm Tuesday meeting @ July 2012 Forum
has x changed below? { double x = 0.3; x *= 7; x /= 7; } do you really want to add a paragraph on how floating point arithmetic works just so that users understand what you mean by "has not changed"? jeff On Wed, Jul 18, 2012 at 10:25 AM, Underwood, Keith D <[email protected]> wrote:
Because that would really suck for the user? :-) The == operator is quite sensible from the "has this changed" perspective... And, meaningless mathematically for floating-point
Keith
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Jeff Hammond Sent: Wednesday, July 18, 2012 11:22 AM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] notes from 5pm Tuesday meeting @ July 2012 Forum
i meant make the user cast. i think you underestimate how often scientists falsely think that == acts on floating point numbers in a mathematically sensible way.
On Wed, Jul 18, 2012 at 10:18 AM, Underwood, Keith D <[email protected]> wrote:
Yes, the MPI library could certainly make that choice in how it used the hardware...
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Jeff Hammond Sent: Wednesday, July 18, 2012 11:09 AM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] notes from 5pm Tuesday meeting @ July 2012 Forum
So your A==B comparison is at the level of bits? Couldn't you just cast double to long then?
Jeff
On Wed, Jul 18, 2012 at 10:03 AM, Underwood, Keith D <[email protected]> wrote:
success=0; while (!success) { A=B; // B is remote, obtained using RMA C=(A*D+E*F) / G; // Everything local, all are doubles if (B == A) {B=C; success = 1}; // This is CAS }
And now you have done a relatively complicated thing on B atomically, though you will suffer if there is contention...
Keith
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Jeff Hammond Sent: Tuesday, July 17, 2012 11:03 PM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] notes from 5pm Tuesday meeting @ July 2012 Forum
What do you mean by "arbitrary atomics"? Are you proposing to do something evil with bitwise comparison on floating-point numbers to realize something other than the obvious meaning of CAS on a float type? If so, just say it, then do it the right way.
We should consider how users will interpret CAS on doubles, for example, and not what some low-level network person can dream up to do with this operation.
What architecture implements remote CAS on floating-point types in hardware right now? Who is proposing it? I invoke the standard (and a bit worn out) argument about implementing MPI-3 entirely in hardware and say that unless someone knows how to do CAS for doubles, it cannot be in the standard.
And to be perfectly honest, I have utterly no idea what you really mean right now so it would be very helpful if you could be very explicit about what you mean by CAS on floating point types. What measure are you using for comparison? Does this have any reason meaning in the context of floating point arithmetic?
Jeff
On Tue, Jul 17, 2012 at 9:40 PM, Underwood, Keith D <[email protected]> wrote:
Floating-point CAS is valid as a way to implement "if this hasn't changed, put the results of this operation in place". It gives you a (moderately expensive, not very fair) way to build a form of arbitrary atomics.
Keith
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Jeff Hammond Sent: Tuesday, July 17, 2012 7:26 PM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] notes from 5pm Tuesday meeting @ July 2012 Forum
I don't know that floating-point compare is well-defined. You really have ask "if abs(x-y)<tolerance" and not "if x==y".
I think only fixed-point types should be valid for CAS.
Jeff
On Tue, Jul 17, 2012 at 6:14 PM, Dave Goodell <[email protected]> wrote:
Discussed the complex types in COMPARE_AND_SWAP issue. "Fortran Integer" category is permitted, but "Complex" category is not, primarily because of width. Since "Fortran Integer" contains wide types, shouldn't we just permit "Complex" and "Floating point" as well? Consensus was to stick with the existing text which permits only "C integer, Fortran integer, Logical, Multi-language types, or Byte".
Group review (esp. Jim & Sreeram): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/187
incorporate Jim suggested change (Torsten): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/271
we think we are unaffected, but need a second check (Jim): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/278
Double-check that C++ is not referenced in the RMA chapter (Pavan): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/281
Needs review (Dave): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/300
Think unaffected, but slim chance of Rput/Rget being affected (Pavan): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/317
Need to check implementation of various (4?) "flush is non-local" changes (Dave): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/270
Need to check disp_unit change (Jim & Sreeram): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/284
After the above items have all been dealt with, all chapter committee members should re-read the whole chapter in the *clean* document (the one _without_ the changebars and colored text) to look for obvious typos and inconsistencies.
-Dave
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Jeff Hammond
