Jeff, great! Several comments: ________ About your https://github.com/jeffhammond/HPCInfo/blob/master/mpi/rma/shared-memory-win... line 48-50 (barrier + 2nd fence) are not needed. fence on line 42 may be needed to guarantee that any initialization is finished. fence on line 52 seems to be also not needed: - not according to #456 - not if substituting the store by a MPI_Put. It would be only needed, if the load on line 51 would be a MPI_Get. ________ About your https://github.com/jeffhammond/HPCInfo/blob/master/mpi/rma/shared-memory-win... Line 17: I would recommend MPI_Abort Lines 48, 50, 58, 59 are not needed. Result: 46 if (rank==0) { 49 *shptr = 42; 52 MPI_Win_post(MPI_GROUP_ONE, 0, shwin); 53 MPI_Win_wait(shwin); 55 } else if (rank==1) { 56 int lint; 61 MPI_Win_start(MPI_GROUP_ZERO, 0, shwin); 62 lint = *rptr; 63 MPI_Win_complete(shwin); This example would illustrate the write-read-rule of #456 (i.e. pattern with variable A) A=val_1 Sync-to-P1 --> Sync-from-P0 load(A) with Sync-to-P1 --> Sync-from-P0 being 2. MPI_Win_post --> MPI_Win_start This example would also work when substituting line 62 by MPI_Get. All Patterns in #456 are based on corresponding Patterns with MPI_Get and MPI_Put. If this example does not work with an existing MPI libary, then because it optimizes the synchronization away because there are no RMA calls. _________ About your https://github.com/jeffhammond/HPCInfo/blob/master/mpi/rma/shared-memory-win... Perfect. This example illustrates again the write-read-rule of #456 (i.e. pattern with variable A) with Sync-to-P1 --> Sync-from-P0 being 4. MPI_Win_sync Any-process-sync- -from-P0-to-P1 --> Any-process-sync- -from-P0-to-P1 4) MPI_Win_sync _________ About your https://github.com/jeffhammond/HPCInfo/blob/master/mpi/rma/shared-memory-win... Perfect. This example illustrates again the write-read-rule of #456 (i.e. pattern with variable A), here the lock/unlock pattern with exclusive lock in P1. _________ About your https://github.com/jeffhammond/HPCInfo/blob/master/mpi/rma/shared-memory-win... I would expect that it works, but it is not based on a pattern that currently exists in #456. This is a bug of #456. The current wording Patterns with lock/unlock synchronization: Within passive target communication, two locks L1 and L2 may be scheduled L1 before L2 or L2 before L1. In the following patterns, the arrow means that the lock in P0 was scheduled before the lock in P1. is not good enough. It should read: Within passive target communication, two locks L1 and L2 may be scheduled "L1 released before L2 granted" or "L2 released before L1 granted" in the case of two locks with at least one exclusive, or in the case of any lock with an additional synchronization (e.g., with point-to-point or collective communication) in between. In the following patterns, the arrow means that the lock in P0 was released before the lock in P1 was granted, independent of the method used to achieve this schedule. In the patters itself, I'll remove the word "shared" and "exclusive". A nice examlple would also be Process P0 Process P1 A=0 B=0 MPI_Win_fence MPI_Win_fence MPI_Win_lock MPI_Win_lock exclusive exclusive A=val_1 B=val_2 Bnew=load(B) Anew=load(A) MPI_Win_unlock MPI_Win_unlock The two rules write-read and read-write together guarantee that either - in P0 Bnew=0 and in P1 Anew=val_1 or - in P0 Bnew=val_2 and in P1 Anew=0 But this is a combination of several basic rules in #456. _________ In General: #456 tries to define these 3*4 + 3 = 15 patterns, which should be enough as far as I oversee, plus two examples, 11.13 to show the translation of the win_sync write-read-pattern and read-write-pattern in real software, and 11.14 the pairing of memory barriers without further synchronization between the processes. Your test examples should be very helpful to test, whether an MPI library fulfills these patterns and to illustrate the compressed wording in #456. Best regards Rolf ----- Original Message -----
From: "Jeff Hammond" <[email protected]> To: "MPI Forum" <[email protected]> Sent: Friday, August 29, 2014 8:25:40 PM Subject: [mpiwg-rma] ticket 456
Rolf,
I find you pseudocode confusion, hence I am creating examples in C that I can compile and run. I will try to come up with a case for everyone of the examples in your ticket. See https://github.com/jeffhammond/HPCInfo/tree/master/mpi/rma/shared-memory-win....
Best,
Jeff
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
participants (1)
Rolf Rabenseifner
