Re: [Mpi3-rma] MPI RMW operations
HI Brian, On Mar 25, 2008, at 11:22 AM, Brian W. Barrett wrote:
That makes sense. How would an MPI_Rmw() call with the IMPLICIT epoch interact with explicit epochs? If the answer is "it wouldn't", I think that's valid. We just need to state it.
I would think the behavior would be undefined or "it wouldn't".
Also, is there any reason we're not using the standard OP defines?
We would need additional operations for RMW/2 (as shown) and restrict other operations that don't apply within the standard. I would also want to carefully look at the implementation costs for using the standard OP defines. - Galen
Brian
On Mar 25, 2008, at 9:14 AM, Howard Pritchard wrote:
Hello Brian,
That was the idea.
The problem as we saw it is that in non-mpi shared memory applications, atomic memory operations are typically used for lightweight synchronization. Having to always use potentially heavyweight lock/ unlock sequences seems to defeat the purpose of adding rmw operations to the mpi specification.
This is a special case of the more general discussion that we should have about global visibility of rma operations, etc.
Howard
If MPI_MODE_PASSIVE_EPOCH_IMPLICIT is not given, is synchronization explicit using the standard epoch functions?
Brian
On Mar 24, 2008, at 9:09 PM, Shipman, Galen M. wrote:
Howard and I have been working on the RMW operations listed below for consideration.
- Galen Shipman - ORNL
Single operand RMW operations
MPI_Rmw(void *operand_addr, int count, MPI_Datatype datatype, void *result_addr, int target_rank, MPI_Aint target_disp, int assert, MPI_RMW_Op op, MPI_Win win)
Two operand RMW operations
MPI_Rmw2(void *operand_addr, int count, MPI_Datatype datatype, void *operand2_addr, void *result_addr, int target_rank, MPI_Aint target_disp, int assert, MPI_RMW_2_Op op, MPI_Win win)
MPI_RMW_Op Predefined RMW single operand operations The following predefined operations are supplied for MPI_RMW and related functions. These operations are invoked by placing the following in op.
Name Meaning
MPI_RMW_INC increment MPI_RMW_PROD product MPI_RMW_SUM sum MPI_RMW_LAND logical and MPI_RMW_LOR logical or MPI_RMW_LXOR logical xor MPI_RMW_BAND binary and MPI_RMW_BOR binary or MPI_RMW_BXOR binary xor MPI_RMW_SWAP swap value
MPI_RMW_2_Op Predefined RMW two operand operations
Name Meaning
MPI_RMW2_MASK_SWAP swap masked bits MPI_RMW2_COMP_SWAP compare and swap
Note: MPI_RMW2_COMP_SWAP is an equality comparison, we may wish to consider multiple comparison operations such as >, >=, <, <=, ==, <>.
Both MPI_Rmw and MPI_Rmw2 take an assert argument. When assert == MPI_MODE_PASSIVE_EPOCH_IMPLICIT MPI_Rmw/2 is equivalent to:
MPI_Win_lock(target_rank,0,win); MPI_Rmw(.....); MPI_Win_unlock(target_rank,0,win);
When assert == MPI_MODE_PASSIVE_EPOCH_IMPLICIT | MPI_MODE_NOCHECK the MPI library knows that the window lock at the target need not be acquired.
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
Howard Pritchard Cray Inc.
-- Brian W. Barrett Dept. 1422: Scalable Computer Architectures Sandia National Laboratories
participants (1)
Shipman, Galen M.
