Re: [Mpi3-rma] Draft Plenary Presentation for MPI RMA
Hi Jim, We addressed the issues below, see inline comments!
These look good. Here's some feedback:
Slide 4: RAW (Read after Write), WAR, WAW are commonly used terms for this, should we use those? The group has a veto-time until tomorrow. It'll be updated if nobody complains.
Slide 21: UPC allows one-sided allocation of distributed shared data through the one-sided call "shared void *upc_global_alloc(size_t nblocks, size_t nbytes)". I think Dan was pointing out that this is impossible in MPI-2. (Still don't think we can support this in MPI-3.) Added a comment, not sure if there is a real application use-case (I can imagine some though).
Slide 22: UPC doesn't allow sharing data on the stack, only heap data can be shared. In general, this is kind of an iffy thing, might encounter some resistance to suggest doing this. Linux is going to initially map the stack to the zero page which is marked copy-on-write, so beyond the parts you have used, the stack doesn't exist. Also as a sub-bullet.
Slide 27: ARMCI has per-operation non-blocking calls. Blocking calls and waits give you local completion and only fence gives you remote completion. Yes, ARMCI has per operation remote completion which we don't support at this point. Proposal 2 had this a while ago but we didn't find a strong use-case (as opposed to the per-operation local completion). Added a comment.
Slide 30: Conflicting relaxed operations issued by a single source will appear in program order when observed by that source. IIRC, a third party need not observe this same order. I think that the result of conflicting relaxed operations issued from different sources is undefined. Added a clarifying comment.
Please check the new version! Thanks & Best, Torsten -- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ ----- Torsten Hoefler | Performance Modeling and Simulation Lead Blue Waters Directorate | University of Illinois (UIUC) 1205 W Clark Street | Urbana, IL, 61801 NCSA Building | +01 (217) 244-7736
participants (1)
Torsten Hoefler
