Re: [mpiwg-rma] MPI RMA status summary
Option A is what the standard says today outside of a sloppy offhand remark in parentheses. See my note please. Jeff Sent from my iPhone
On Sep 30, 2014, at 7:05 AM, Rolf Rabenseifner <[email protected]> wrote:
I strongly agree with your statement:
These piecemeal changes are one of the sources of our problems.
I only wanted to strongly say, that I would never vote for your a), because it is not backward compatible to what is already used. And with b) I've the problem that b1) is clear to me (see #456), but the Win_flush semantics for load/store is unclear to me.
Of course, a total solution is needed and not parts of it. #456 is such a trial for a complete solution.
Rolf
----- Original Message -----
From: "William Gropp" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Tuesday, September 30, 2014 3:19:06 PM Subject: Re: [mpiwg-rma] MPI RMA status summary
I disagree with this approach. The most important thing to do is to figure out the correct definitions and semantics. Once we agree on that, we can determine what can be handled as an errata and what will require an update to the chapter and an update to the MPI standard. These piecemeal changes are one of the sources of our problems.
Bill
On Sep 30, 2014, at 7:38 AM, Rolf Rabenseifner <[email protected]> wrote:
Vote for 1 of the following:
a) Only Win_sync provides memory barrier semantics to shared memory windows b) All RMA completion/sync routines (e.g., MPI_Win_lock, MPI_Win_fence, MPI_Win_flush) provide memory barrier semantics c) Some as yet undetermined blend of a and b, which might include additional asserts d) This topic needs further discussion
Because we only have to clarify MPI-3.0 (this is an errata issue) and - obviously the MPI Forum and the readers expected that MPI_Win_fence (and therefore also the other MPI-2 synchronizations MPI_Win_post/start/complete/wait and MPI_Win_lock/unlock) works if MPI_Get/Put are sustituted by shared memory load/store (see the many Forum members as authors of the EuroMPI paper) - and the Forum decided that also MPI_Win_sync acts as if a memory barrier is inside, for me, - a) cannot be chosen bacause an erratum cannot remove a given functionality - and b) is automatically given, see reasons above. Therefore #456.
The only open question for me is about the meaning of MPI_Win_flush. Therefore MPI_Win_flush is still missing in #456.
Therefore for me, the Major choices seems to be b1) MPI-2 synchronizations + MPI_Win_sync b2) MPI-2 synchronizations + MPI_Win_sync + MPI_Win_flush
For this vote, I clearly want to see a clear proposal about the meaning of MPI_Win_flush together with sared memory load/store, hopefully with the notation used in #456.
Best regards Rolf
From: "William Gropp" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Monday, September 29, 2014 11:39:51 PM Subject: Re: [mpiwg-rma] MPI RMA status summary
Thanks, Jeff.
I agree that I don’t want load/store to be considered RMA operations. But the issue of the memory consistency on RMA synchronization and completion operations to a shared memory window is complex. In some ways, the most consistent with RMA in other situations is the case of MPI_Win_lock to your own process; the easiest extension for the user is to have reasonably strong memory barrier semantics at all sync/completion operations (thus including Fence). As you note, this has costs. At the other extreme, we could say that only Win_sync provides these memory barrier semantics. And we could pick a more complex blend (yes for some, no for others).
One of the first questions is whether we want to only Win_sync, all completion/sync RMA routines, or some subset to provide memory barrier semantics for shared memory windows (this would include RMA windows that claimed to be shared memory, since there is a proposal to extend that property to other RMA windows). It would be good to make progress on this question, so I propose a straw vote of this group by email. Vote for 1 of the following:
Note that I’ve left off what “memory barrier semantics” means. That will need to be precisely defined for the standard, but I believe we know what we intend for this. We specifically are not defining what happens with non-MPI code. Also note that this is separate from whether the RMA sync routines appear to be blocking when applied to a shared memory window; we can do a separate straw vote on that.
Bill
On Sep 29, 2014, at 3:49 PM, Jeff Hammond < [email protected] wrote:
On Mon, Sep 29, 2014 at 9:16 AM, Rolf Rabenseifner < [email protected] > wrote:
Only about the issues on #456 (shared memory syncronization):
For the ones requiring discussion, assign someone to organize a position and discussion. We can schedule telecons to go over those issues. The first item in the list is certainly in this class.
Who can organize telecons on #456. Would it be possible to organize a RMA meeting at SC?
I will be there Monday through part of Thursday but am usually triple-booked from 8 AM to midnight.
The position expressed by the solution #456 is based on the idea that the MPI RMA synchronization routines should have the same outcome when RMA PUT and GET calls are substituted by stores and loads.
The outcome for the flush routines is still not defined.
It is interesting, because the standard is actually conflicting on whether Flush affects load-store. I find this incredibly frustrating.
Page 450:
"Locally completes at the origin all outstanding RMA operations initiated by the calling process to the target process specified by rank on the specified window. For example, after this routine completes, the user may reuse any buffers provided to put, get, or accumulate operations."
I do not not think "RMA operations" includes load-store.
Page 410:
"The consistency of load/store accesses from/to the shared memory as observed by the user program depends on the architecture. A consistent view can be created in the unified memory model (see Section 11.4) by utilizing the window synchronization functions (see Section 11.5) or explicitly completing outstanding store accesses (e.g., by calling MPI_WIN_FLUSH)."
Here it is unambiguously implied that MPI_WIN_FLUSH affects load-stores.
My preference is to fix the statement on 410 since it is less canonical than the one on 450, and because I do not want to have a memory barrier in every call to WIN_FLUSH.
Jeff
I would prefere to have an organizer of the discussion inside of the RMA subgroup that proposed the changes for MPI-3.1 rather that I'm the organizer. I tried to bring all the input together and hope that #456 is now state that it is consistent itsself and with the expectations expressed by the group that published the paper at EuroMPI on first usage of this shared memory interface.
The ticket is (together with the help of recent C11 standadization) on a good way to be also consistent with the compiler optimizations - in other words - the C standardization body has learnt from the pthreads problems. Fortran is still an open question to me, i.e., I do not know the status, see https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/456#comment:13
Best regards Rolf
From: "William Gropp" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Thursday, September 25, 2014 4:19:14 PM Subject: [mpiwg-rma] MPI RMA status summary
I looked through all of the tickets and wrote a summary of the open issues, which I’ve attached. I propose the following:
Determine which of these issues can be resolved by email. A significant number can probably be closed with no further action.
For those requiring rework, determine if there is still interest in them, and if not, close them as well.
Comments?
Bill
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Jeff Hammond
