Re: [mpiwg-rma] Short question on the ccNUMA memory reality
Bronis and all, yes, after all what I now know, I expect that you are right. My proposal for Bill G. was based on guarantees from rank to rank only with synchronizations in between. Thanks for all the answers. Rolf ----- Original Message -----
From: "Bronis R. de Supinski" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Cc: "Bill Long" <[email protected]> Sent: Tuesday, August 5, 2014 5:00:15 PM Subject: Re: [mpiwg-rma] Short question on the ccNUMA memory reality
Rolf:
Re:
thank you for your answer. I was not precise enough with my question. My notations should represent store and load instructions, i.e., assembler level, i.e., what's going on hardware level.
The "level" is not really relevant. As Pavan noted, unless you use atomic instructions, you get no guarantees. With ordinary loads and stores, your snippets all contain race conditions. The exact result will depend on the system but as a rule, you can assume that a program with races provides NO guarantees.
Sure, you can eliminate the values coming from registers but they can come from the cache and you are not provide any general atomicity guarantees. Most hardware will provide bit-level atomicity on ordinary loads and stores but if you straddle a cache line, you lose those guarantees.
Overall, the issues that arise are more complex than you want to deal with. That's why we have compilers for threaded programs. Simply put, shared memory programming without compiler assistance is not something ordinary programmers should do.
Bronis
x should be part of an MPI shared memory allocated with MPI_Win_allocate_shared, i.e., the assembler on rank 0 does two stores and the assembler on rank 1 does four loads.
The code was
rank 0 rank 1 _______ print x x=val_1 print x x=val_2 print x _______ print x
When I understand Bill Long correctly, then the 4 load(x) end up in
old_val val_2 (because it was going through a very slow network path) val_1 val_2 wheras three enterleaved load instructions on rank 0 (i.e., in the same execution stream (thread) as the two stores) will always see old_val val_1 val_2
This is independent of compilers, because I only want to look at assembbler level.
Bill Long, are you sure? I would expect that all loads go through the 1st Level Cache and as soon as it sees val_2 it should not be possible to see with a later issued instruction val_1.
Best regards Rolf
From: "Bill Long" <[email protected]> To: "Rolf Rabenseifner" <[email protected]> Cc: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Tuesday, August 5, 2014 3:12:58 PM Subject: Re: Short question on the ccNUMA memory reality
Hi Rolf,
I assume you are expecting answers from people like Pavan and Bill G for the MPI RMA perspective, and for the Fortran rules from me. (For Fortran, map Rank 0 -> image 1 and Rank 1 -> Image 2).
On Aug 5, 2014, at 2:33 AM, Rolf Rabenseifner <[email protected]> wrote:
Dear expert on ccNUMA,
three questions, which hopefully may be trivial:
1. Question (sequential consistency on one location): ------------
Do I understand correctly that in the following patter on a shared Memory or a ccNUM shared memory
I assume you mean what I think of as distributed memory here. Otherwise, these are questions about OpenMP, and the rank 0 / rank 1 separation does not make sense.
rank 0 rank 1 print x x=val_1 print x x=val_2 print x print x
This depends on whether x is declared in a way that makes it accessible from a remote rank. If not, then the code is illegal. So I’ll assume it is accessible.
Since there is no synchronization between rank 0 and rank 1, compiler elimination of the x = val_1 assignment is allowed (and likely expected).
Even if the assignment is not eliminated, the print x on rank 1 involves a “get” of x from rank 0. Assuming it is declared volatile, to eliminate the “snap to local temp” optimization on rank 1, it is still possible to get the values out of order. For example, the print #2 could get routed through the network via some extra long path, while print #3 could get routed on the fastest path, resulting in the two “get” operations appearing at rank 0 in an unpredictable order.
[Note that by the Fortran rules, the code is not legal anyway. If you define a variable on one rank and reference it (the print counts as a reference) on another rank the execution segments containing the definition and reference have to be ordered unless the definition and reference are both explicitly atomic. Segment ordering is done with synchronization statements.]
the print statements can print only in the following sequence - some times the previous value - some times val_1 - and after some time val_2 and it then stays to print val_2
and that it can never be that a sequence with val_2 before val_1 can be produced, i.e., old_val val_2 val_1 val_2 is impossible.
Also other values are impossible, e.g., some bit or byte-mix from val_1 and val_2.
On most hardware, assuming the values are “normal” size, such as 64-bit, you will not get mixed bits. However, if you want to ensure that, use the atomic get and put intrinsics. If the accesses had been properly ordered by synchronizations, then you do not need the atomics to ensure whole values.
2. Question: ----------- What is the largest size that the memory operations are atomic, i.e., that we do not see a bit or byte-mix from val_1 and val_2? Is it 1, 4, 8, 16 bytes or can it be a total struct that fits into a cacheline?
Since the types in Fortran are parameterized, the processor supplies a KIND value for the integer and logical types for which atomic operations are supported. Typically kind corresponds to 64 bits, but could be 32 on some architectures.
3. Question (about two updates): -----------
rank 0 rank 1 x=x_ld y=yold ---- necessary synchronizations ----- print x (which shows xold) print y (which shows yold) ---- necessary synchronizations ----- x=xnew y=ynew print x print y after some time print x print y
Possible results are - xold,yold xold,yold xnew,ynew - xold,yold xnew,yold xnew,ynew - xold,yold xold,ynew xnew,ynew i.e., the y=ynew can arrive at another process faster than the x=xnew, although the storing process issues the stores in the sequence x=xnew, y=ynew. - xold,yold xnew,ynew xnew,ynew
The assignments should represent the store instructions, and not the source code (because the compiler may modify sequence of instructions compared to the source code)
Do I understand correctly, that the sequence of two store instructions two two different locations in one process may be visible at another process in a different sequence?
Correct. As before, the “get” operations implied in the print statements could arrive out of order. Also, while unlikely, the compiler could decide to reverse the order of the assignments since they are independent. (Assuming x and y cannot be aliased by, for example, being pointers.)
Cheers, Bill
I ask all these questions to understand which memory model can be defined for MPI shared memory windows.
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
From: "William Gropp" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Cc: "Bill Long" <[email protected]> Sent: Tuesday, August 5, 2014 2:38:07 PM Subject: Re: [mpiwg-rma] Short question on the ccNUMA memory reality
Question 1 is hard to answer. First, as it came out in my output, the first and last “print x” straddle the two ranks, so I’m not sure what that means. But the following is valid for the compiler:
On rank 0. Since x = val_2 follows x = val_1 with no intervening use of x, a good optimizing compiler may eliminate the store to x with val_1 as unnecessary.
On rank 1, Since x is never assigned in this block, a compiler is permitted to make a copy in a register (which would have the value x had before this block was entered) and than print that value each time print is called (e.g., it could build the call stack in memory, and just pass that unchanged call stack to print for each call).
And don’t forget - there’s a difference between when the print completes on a process/thread and when the output appears - the system could flush all print output from rank 1 before any print output from rank 0 appears.
If x is volatile, then the compiler isn’t free to do the second (save x and never load it again).
Bill
William Gropp Director, Parallel Computing Institute Thomas M. Siebel Chair in Computer Science
University of Illinois Urbana-Champaign
On Aug 5, 2014, at 2:53 AM, Balaji, Pavan < [email protected] > wrote:
Huh?
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Rolf Rabenseifner
