Re: [mpiwg-rma] Draft MPI RMA chapter update
Thanks. I’ve fixed the “much”. As Rajeev notes, the only changes are the text in red, and this was just fixing typos and made no semantic changes. Bill On May 4, 2015, at 12:24 AM, Thakur, Rajeev <[email protected]> wrote:
If we are going to fix "It is often useful in a put operation to combine the data moved to the target process with the data that resides at that process, rather than replacing it."
The only change made was "rather then (typo) replacing the data" => "rather than replacing it"
page 46 line 10-11: "each access epoch much target a different process." s/much/must/
Good catch. That is a new error introduced in the editing.
The text added on page 47 "Completes an RMA access epoch started by a call to MPI_WIN_LOCK on window win." and "Completes a shared RMA access epoch started by a call to MPI_WIN_LOCK_ALL on window win." appear to add a semantic restriction not present in MPI 3.0,
The only change made was that the parameters to Win_lock(...) and lock_all(...) were omitted. They were present earlier.
Rajeev
On May 3, 2015, at 4:53 PM, Jeff Hammond <[email protected]> wrote:
(1)
If we are going to fix "It is often useful in a put operation to combine the data moved to the target process with the data that resides at that process, rather than replacing it." in 11.3.4, we should go all the way to
"It is often useful in a remote update operation to combine the data moved to the target process with the data that resides at that process, rather than replacing it."
because "put" is not a superset of MPI_Put and MPI_Accumulate.
(2)
(3)
The text added on page 47 "Completes an RMA access epoch started by a call to MPI_WIN_LOCK on window win." and "Completes a shared RMA access epoch started by a call to MPI_WIN_LOCK_ALL on window win." appear to add a semantic restriction not present in MPI 3.0, unless it says somewhere else that LOCK_ALL must be matched by UNLOCK_ALL and not by the appropriate number of UNLOCK calls, and vice versa. If it says this, I can't remember where it is.
And if one wants to add this text, it would seem symmetric to specify that FLUSH_ALL and FLUSH_LOCAL_ALL should be associated with LOCK_ALL epochs and not N*LOCK epochs. However, I do not think this is something we should do, and thus I infer we want to be less specific in the previous instance, meaning, we should use
"Completes an RMA access epoch started by a call to MPI_WIN_LOCK or MPI_WIN_LOCK_ALL on window win."
for both cases on page 47.
Jeff
On Sun, May 3, 2015 at 8:33 AM, William Gropp <[email protected]> wrote:
Attached is an update to the RMA chapter. This does not introduce or change any features; it simply corrects some language and appearance (spacing) and removes a few errors in the text. New text is in red; deletions are not shown. Also attached is the svn diff for these items. The chapter authors reached consensus on these; we have a list of things that the RMA group should discuss at the next meeting. Also note, because of the short time left, the other chapter authors have not had a chance to review these - any errors are mine.
If you find a problem with these updates (not just awkward wording, or a new problem), respond to the whole group so that we can discuss it as quickly as possible.
Bill
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
William Gropp
