Re: [mpiwg-rma] Bugs in RMA in current MPI standard - Re: Summary of MPI RMA WG meeting on Sept 21, 2018
Dear Pavan and all, I just found the ticket from Bill, Sep. 19, 2016 and labeled it with wg-rma, MPI-4.0, Chattanooga, reading. Still within Monday Feb. 18, 2019 deadline for Chattanooga when using Hawaiian timezone ;-) Therefore, I'll also send out the Forum-Mail for the reading before midnight on Hawaii. I hope, that this is okay for you all. The further going solution, as proposed by Pavan should be discussed independently, because also allowing MPI_Win_create, i.e., removing the whole restriction, may have Performance aspects if the progress implementation of an MPI library is not identical for MPI_Win_create and MPI_Win_create_dynamic + MPI_Win_attach. Pavan, I hope that you can add the pull request for this ticket today. As change-log, I propose \item Section~\ref{sec:1sided-lock} on page~\pageref{sec:1sided-lock}. \newline The rule that implementors may restrict the use of \RMA/ communication that is synchronized with \mpifunc{MPI\_WIN\_LOCK}, \mpifunc{MPI\_WIN\_LOCK\_ALL} and other lock calls to windows in memory allocated by \mpifunc{MPI\_ALLOC\_MEM}, \mpifunc{MPI\_WIN\_ALLOCATE}, or attached with \mpifunc{MPI\_WIN\_ATTACH}, is extended by memory allocated with \mpifunc{MPI\_WIN\_ALLOCATE\_SHARED}. ---- With this, we have the change-log also visible in the index entry of all related routines, which helps that people can find the change-log. Best regards Rolf ----- Original Message -----
From: "MPI WG Remote Memory Access working group" <[email protected]> To: "Pavan Balaji" <[email protected]> Cc: "Rolf Rabenseifner" <[email protected]>, "MPI WG Remote Memory Access working group" <[email protected]> Sent: Sunday, February 17, 2019 1:15:53 PM Subject: Re: [mpiwg-rma] Bugs in RMA in current MPI standard - Re: Summary of MPI RMA WG meeting on Sept 21, 2018
+1 on removing that text. The intent was to allow Win_create too, which we somehow missed. The original MPI-2 intent was, to allow only memories that were allocated by an MPI library routine and ***not*** just handed over by the user (as with MPI_WIN_CREATE). This means, MPI_WIN_CREATE was originally never intented.
In MPI-2, it was therefore only MPI_ALLOC_MEM. I do not understand, why MPI_WIN_ATTACH was added to the list. And I expect that MPI_WIN_ALLOCATE_SHARED was overseen. But as Jeff said, with MPI_WIN_ATTACH in the list, this restriction does not make sense anymore.
Is there a ticket resolving this Problem in MPI-4.0 (Deadline seems to be today (or Monday noon?).
Best regards Rolf
From: "Pavan Balaji" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Cc: "Pavan Balaji" <[email protected]>, "Rolf Rabenseifner" <[email protected]>, "Jeff Hammond" <[email protected]> Sent: Wednesday, September 26, 2018 6:16:25 PM Subject: Re: [mpiwg-rma] Bugs in RMA in current MPI standard - Re: Summary of MPI RMA WG meeting on Sept 21, 2018
On Sep 25, 2018, at 9:38 PM, Jeff Hammond via mpiwg-rma <[email protected]> wrote: Implementors may restrict the use of RMA communication that is synchronized by lock calls to windows in memory allocated by MPI_ALLOC_MEM (Section 8.2), MPI_WIN_ALLOCATE (Section 11.2.2), MPI_WIN_ALLOCATE_SHARED (Section 11.2.3), or attached with MPI_WIN_ATTACH (Section 11.2.4). Locks can be used portably only in such memory.
I am not certain that this change is consistent with the original intent, but we should just remove this text, because it does not make sense anymore. If MPI_Win_attach is sufficient to allow locks, then MPI_Win_create should be there, because one can implement MPI_Win_create in terms of MPI_Win_create_dynamic+MPI_Win_attach.
-- Pavan
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpiwg-rma mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-rma
participants (1)
Rolf Rabenseifner
