Re: [Mpi3-rma] Use cases for RMA
Bill, Here are some of the MPI RMA requirements for Global Arrays (GA) and ARMCI. ARMCI is GA's runtime system. GA/ARMCI exploits native network communication interfaces and system resources (such as shared memory) to achieve the best possible performance of the remote memory access/one-sided communication. GA/ARMCI relies *heavily* on optimized contiguous and non-contiguous RMA operations (get/put/acc). For GA/ARMCI and its applications, below are some specfic examples of operations that are hard to achieve in MPI-2 RMA. 1. Memory Allocation: (This might be an implementation issue) The user or library implementors should be able to allocate memory (e.g. shared memory), and register with MPI. This is useful in case of Global Arrays/ARMCI, which use RMA across nodes and shared memory within nodes. ARMCI allocates shared memory segment, and pins/registers with the network. 2. Locks: Should be made optional to keep the RMA programming model simple. If the user doesnot require concurrency, then locks are unnecessary. Enforcing to use locks as default might introduce unnecessary bugs if not carefully programmed (esp. at the level of of extreme scale systems, it is hard to debug). 3. Support for non-overlapping concurrent operations in a window. 4. RMW Operation - Useful for implementing dynamic load balancing algorithms (e.g. task queues/work stealing, group/global counters, etc). The above are feature requirements rather than performance issues, which are implementation specific. If you have any questions, I would be happy to explain the above in detail. Thanks, -Manoj. --------------------------------------------------------------- Manojkumar Krishnan High Performance Computing Group Pacific Northwest National Laboratory Ph: (509) 372-4206 Fax: (509) 372-4720 http://hpc.pnl.gov/people/manoj --------------------------------------------------------------- On Wed, 3 Mar 2010, William Gropp wrote:
I went through the mail that was sent out in response to our request for use cases, and I must say it was underwhelming. I've included a short summary below; based on this, we aren't looking at the correct needs. I don't think that these are representative of *all* of the needs of RMA, but without good use cases, I don't see how we can justify any but the most limited extensions/changes to the current design. Please (a) let me know if I overlooked something and (b) send me (and the list) additional use cases. For example, we haven't included any of the issues needed to implement PGAS languages, nor have we addressed the existing SHMEM codes. Do we simply say that a high-quality implementation will permit interoperation with whatever OpenSHMEM is? And what do we do about the RMI issue that one of the two use cases that we have raises?
Basically, I received two detailed notes for the area of Quantum Chemistry. In brief:
MPI-2 RMA is already adequate for most parts, as long as the implementation makes progress (as it is required to) on passive updates. Requires get or accumulate; rarely requires put. Dynamic load balancing (a related but separate issue) needs some sort of RMW. (Thanks to Jeff Hammond)
More complex algorithms and data structures appear to require remote method invocation (RMI). Sparse tree updates provide one example. (Thanks to Robert Harrison)
Bill
William Gropp Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Manojkumar Krishnan
