Re: [mpiwg-rma] Problems with RMA synchronization in combination with load/store shared memory accesses
Jim, thank you for your analysis. Answers see below. ----- Original Message -----
From: "Jim Dinan" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Friday, March 21, 2014 8:14:22 PM Subject: Re: [mpiwg-rma] Problems with RMA synchronization in combination with load/store shared memory accesses
Rolf,
This line is incorrect: MPI_Win_fence(MPI_MODE_NOSTORE + MPI_MODE_NOPRECEDE, win_ rcv_buf _left );
You need to do a bitwise OR of the assertions (MPI_MODE_NOSTORE | MPI_MODE_NOPRECEDE).
Yes, you are right, but this cannot be the reasons for the problems according to MPI-3.0 p451:28-32. The Fortran versions show the same problems.
In halo_1sided_store_win_alloc_shared.c, you are doing stores within the epoch, so MPI_MODE_NOSTORE looks like an incorrect assertion on the closing fence.
Yes, but I do remote stores and no local stores. But you may be right, because the text p452:9-10 does not require that the stores are local stores. When I remember correctly, then removing this hint does not produce correct results. I'll re-check.
Following the Fence epoch, you are reading from the left/right recv buffers. That also needs to be done within an RMA epoch, if you are reading non-local data.
This reading is only on the local recv_buf_left/right. But it is included in the RMA epoch starting with the second fence and ending with the first fence in the next loop Iteration.
~Jim.
Best regards Rolf
On Fri, Feb 21, 2014 at 6:07 AM, Rolf Rabenseifner < [email protected] > wrote:
Dear member of the RMA group and especially the mpich developers,
I have real problems with the new shared memory in MPI-3.0, i.e., the load/stores together with the RMA synchronization causes wrong execution results.
The attached 1sided_halo_C_mpich_problems_rabenseifner.tar.gz or .zip contains
- 1sided/halo_1sided_put_win_alloc.c
The basis that works. It uses MPI_Put and MPI_Win_fence for duplex left/right halo communication.
- 1sided/halo_1sided_store_win_alloc_shared.c
This is the same, but a shared memory window is used and the MPU_Put is substituted by storing the data in the neighbors window. Same MPI_Win_fence with same assertions.
This does not work, although I'm sure that my assertions are correct.
Known possibilities: - I'm wrong and was not able to understand the assertions on MPI-3.0 p452:8-19. - I'm wrong because it is invalid to use the MPI_Win_fence together with the shared memory windows. - mpich has a bug. (The first two possibilities are the reason, why I use this Forum email list)
- 1sided/halo_1sided_store_win_alloc_shared_w-a-cray.c
This is a work-around-for Cray that works on our Cray and does not use MPI_MODE_NOPRECEDE and MPI_MODE_NOSUCCEED. It also runs on another mpich installation.
- 1sided/halo_1sided_store_win_alloc_shared_pscw.c
Here, MPI_Win_fence is substituted by Post-Start-Complete-Wait and it does not work for any assertions.
Same possibilities as above.
- 1sided/halo_1sided_store_win_alloc_shared_query.c - 1sided/halo_1sided_store_win_alloc_shared_query_w-a-cray.c
Same as halo_1sided_store_win_alloc_shared.c but non-contigues windows are used. Same problems as above.
- 1sided/halo_1sided_store_win_alloc_shared_othersync.c
This version uses the synchronization according to #413 and it is tested and works on two platforms.
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Rolf Rabenseifner
