Re: [mpiwg-rma] same_op_no_op and SHMEM
The motivation was that it’s hard to maintain atomicity when different operations are done. For example, if the hardware only supports some atomic operations, but not all, this might result in some operations happening in hardware and some in software making atomicity hard. In such cases, the MPI implementation might need to fall back to software-only implementations. -— Pavan On Oct 24, 2013, at 12:23 PM, Jeff Hammond <[email protected]> wrote:
I recall that Brian and/or Keith wanted same_op_no_op because of SHMEM. However, SHMEM requires the use of MPI_NO_OP (for atomic Get via Get_accumulate), MPI_REPLACE (for atomic Put via Accumulate) and MPI_SUM (for add, fadd, inc and finc). So what is the benefit of same_op_no_op to SHMEM? Perhaps I remember completely wrong and the motivation was something that does not use the latter atomics. Or perhaps it is common for SHMEM codes to not use these and thus the assumption is MPI_SUM can be ignored.
Jeff
-- Jeff Hammond [email protected] _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
