Re: [mpiwg-rma] [Mpi-forum] 3/14: Formal Readings
On Thu, Feb 20, 2014 at 9:16 AM, Rolf Rabenseifner <[email protected]> wrote:
Most users don't understand this and write code that is incorrect.
Therefore such a clarification is essential.
I dispute the need for the MPI standard to educate programmers about the pitfalls of shared memory programming. The standard is not a programmer manual. Does C99 standard have text on how shared memory works? Jeff
----- Original Message -----
From: "William Gropp" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Thursday, February 20, 2014 3:46:14 PM Subject: Re: [mpiwg-rma] [Mpi-forum] 3/14: Formal Readings
I want to emphasize Jeff's point about the "eventually" - this is the case not just for MPI unified but for most shared memory models (I say most because you can build hardware and software to force changes to be visible immediately, but at a cost in performance). Most users don't understand this and write code that is incorrect.
Bill
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Thomas M. Siebel Chair in Computer Science
University of Illinois Urbana-Champaign
On Feb 20, 2014, at 5:09 AM, Jeff Hammond wrote:
The critical word I think you're overlooking is "eventually".
Win_sync induces the public-private alignment at the point of call. It also syncs between diff procs doing load-store as a wrapper around the processor-specific memory barrier.
If we want to add pedantic text, that's fine though, but I still don't think it's critical.
Jeff
Sent from my iPhone
On Feb 20, 2014, at 3:55 AM, Rolf Rabenseifner < [email protected]
wrote:
Jeff,
the problem is that we are in the unified model.
I expect that nobody would expect that
"the purposes of synchronizing the private and public window"
(from your cited text) is needed if
"public and private copies are identical",
see MPI-3.0 p436:37-40, which say
"In the RMA unified model, public and private copies are identical and updates via put
or accumulate calls are eventually observed by load operations without additional RMA
calls. A store access to a window is eventually visible to remote get or accumulate calls
without additional RMA calls."
MPI-3.0 p456:3ff say
"In the MPI_WIN_UNIFIED memory model, the rules are much simpler because the public
and private windows are the same. ..."
and especially p456:34-36
"This permits updates to memory with
store operations without requiring an RMA epoch."
I read all this text and thought that I do not need any additional
synchronization besides the (empty) pt-to-pt Messages.
The members of the RMA working group convinced me
that the MPI_WIN_SYNC is needed to guarantee that a locally
visible X=13 may not be remote visible without the MPI_WIN_SYNC
although the MPI-3.0 text clearly says
"in the RMA unified model, public and private copies are identical".
Currently, there is no example in this section showing the behavior
in the unified model with only using load/store, i.e. without any
RMA call. All existing examples use some PUT or GET.
I tried to fill this gap to prevent any mis-interpretation
of p436:37-40 and p456:3-p457:3.
Best regards
Rolf
To: "MPI WG Remote Memory Access working group" < [email protected] >
Cc: "Jeff Squyres" < [email protected] >
Sent: Wednesday, February 19, 2014 7:19:14 PM
Other than interactions that are unique to Fortran, I do not
understand what is unclear about the following text from MPI-3:
"For the purposes of synchronizing the private and public window,
MPI_WIN_SYNC has the effect of ending and reopening an access and
exposure epoch on the window."
Thus, the valid usage is prescribed by its effective equivalence to
"MPI_WIN_UNLOCK; MPI_WIN_LOCK;". I apologize if the WG has been
sloppy in how we've discussed MPI_WIN_SYNC, but I do not feel the
standard is ambiguous.
Now, if you are arguing that Fortran is a special problem for
MPI_WIN_SYNC, then I will gladly support your argument that Fortran
is
a special problem for lots of things :-)
Jeff
On Wed, Feb 19, 2014 at 11:44 AM, Rolf Rabenseifner
< [email protected] > wrote:
Jim,
Yes Jim, you are fully right and I updated ticket 413 according to
your corrections.
Thank you for your carefully reading and your corrections.
The reason for this ticket is very simple:
Nothing about the use of MPI_Win_sync for the use-case
in this example is really explained by MPI-3.0.
I expect, that for MPI-4.0, the rules for RMA synchronization
for shared memory windows must be revisited.
But this would be another ticket.
Best regards
Rolf
Cc: "Rolf Rabenseifner" < [email protected] >, "Jeff Squyres"
Sent: Monday, February 17, 2014 11:30:42 PM
Rolf,
I think this ticket needs to be reviewed by the RMA WG before
moving
it forward. I would suggest updating the text to incorporate the
following changes:
Example 11.13 demonstrates the proper synchronization in the
unified
memory model when a data transfer is implemented with load and
store
(instead of MPI_PUT or MPI_GET) and the synchronization between
processes is performed using point-to-point communication. The
synchronization between processes must be supplemented with a
memory
synchronization through calls to MPI_WIN_SYNC, which act locally
as
a processor-memory barrier. In Fortran, reordering of the
MPI_WIN_SYNC calls must be prevented with MPI_F_SYNC_REG
operations.
The variable X is contained within a shared memory window and X
corresponds to the same memory location at both processes. The
MPI_WIN_SYNC operation performed by process A ensures completion
of
the load/store operations issued by process A. The MPI_WIN_SYNC
operation performed by process B ensures that process A's updates
to
X are visible to process B.
In the example, I don't see the reason for the second set of SYNC
operations after B's read of X. If A updates X and B only reads
it,
the second send/recv synchronization should be sufficient. That
is,
B has not made any updates to X that need to be made visible A,
and
B's read of X will be ordered because of the send operation. The
F_SYNC could still be needed to preserve this ordering.
~Jim.
On Mon, Feb 17, 2014 at 12:23 PM, Jeff Hammond <
Switching to the WG list so that everyone is involved...
I do not see adding an example as so urgent that it needs to be
dealt
with at the next meeting, given how overloaded the relevant people
are.
Honestly, it is more likely to be read by users if the example and
commentary on it are the subject of a blog post on Squyres' blog.
At
the very least, that will ensure Google indexes it and thus
curious
people will find it (as much cannot be said for the MPI standard
itself).
Jeff
On Mon, Feb 17, 2014 at 10:50 AM, Rolf Rabenseifner
Pavan,
do you put also #413 on the list.
I believe, it's better to have it on the list
although it is only an example and therefore the RMA group
may put it on the errata without plenary.
Please can you do all what is needed
that it comes on the MPI-3.0 errata list.
Best regards
Rolf
Pavan,
thank you for supporting it in the March meeting (Rajeev
will
not
be there).
Is there a RMA WG Meeting at the March Forum Meeting?
Will you do an MPI-3.0 errata plenary reading
or will you put it into the errata by WG dicision,
because it is only an example?
In both cases #413 should be latest tomorrow on the agenda.
Because it is one block of text at one precise location,
the ticket format may be enough formalism, i.e., no extra
pdf.
To: "Main MPI Forum mailing list" <
Sent: Monday, February 17, 2014 4:35:51 PM
Subject: [Mpi-forum] 3/14: Formal Readings
Hi All,
The RMA and Hybrid working groups would like to put forward the
following tickets for formal readings at the upcoming meeting:
#380 - Endpoints proposal
https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/380/mpi-repor...
Read by: Pavan Balaji
#349, #402, #404 - Address arithmetic proposal
https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/349/review-34...
Read by: David Goodell
#369 - Add same_disp_unit info key for RMA window creation
https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/369/mpi-repor...
Please add these to the agenda. Unfortunately, I will not be
able
to
attend this meeting, so I have included a contact person for
each
ticket.
Thanks!
~Jim.
mpi-forum mailing list
http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
Dr. Rolf Rabenseifner . . . . . . . . . .. email
High Performance Computing Center (HLRS) . phone
++49(0)711/685-65530
University of Stuttgart . . . . . . . . .. fax ++49(0)711 /
685-65832
Head of Dpmt Parallel Computing . . .
www.hlrs.de/people/rabenseifner
Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room
1.307)
Jeff Hammond
mpiwg-rma mailing list
http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
685-65832
1.307)
Jeff Hammond
Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]
High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530
University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832
Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner
Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Jeff Hammond [email protected]
participants (1)
Jeff Hammond
