Re: [Mpi3-rma] Draft Plenary Presentation for MPI RMA
On 02/04/2011 03:10 PM, Torsten Hoefler wrote:
On Fri, Feb 04, 2011 at 02:35:45PM -0600, Pavan Balaji wrote:
On 02/04/2011 01:14 PM, Torsten Hoefler wrote:
Slide 27: ARMCI has per-operation non-blocking calls. Blocking calls and waits give you local completion and only fence gives you remote completion. Yes, ARMCI has per operation remote completion which we don't support at this point. Proposal 2 had this a while ago but we didn't find a strong use-case (as opposed to the per-operation local completion). Added a comment.
No, ARMCI doesn't have per operation remote completion; only local completion. Attached the slides I had distributed earlier about this for your reference.
Ok, I got this impression from our previous discussion. So Jim, what did your comment then mean?
I meant the same thing as what Pavan wrote, but had a language fail: ARMCI gives per-operation local completion for non-blocking operations. Blocking operations are locally complete when they return. Bulk remote completion is accomplished through fence. ~Jim.
participants (1)
James Dinan
