Re: [Mpi3-rma] RMA synchronization optimization [was: Updated MPI-3 RMA proposal 1]
Doug, Yes, MPI calls the lock/unlock and fences as epochs. But what I was trying to point out is that your RMA operations are restricted within win_create/free. Anyway, don't worry about that -- my attempt to clarify ended up creating more confusion. With respect to the your description below, there's still no detail on why multiple epoch type possibilities are making the code slower. Your description below continues to argue that it makes it more complex, but there's no clear description of how this complexity translates to performance impact. -- Pavan On 06/23/2010 11:42 AM, Douglas Miller wrote:
Does the MPI standard state that RMA operations can commence without having called FENCE, START, or LOCK? Is it legal to do WIN_CREATE, RMA..., WIN_FREE? Doesn't the MPI2 spec talk about epochs being between synch calls? like between two FENCE calls, or between START and COMPLETE or POST and WAIT, or between LOCK and UNLOCK? Certainly a rank may be the target of a LOCK without having performed any explicit operation aside from WIN_CREATE.
I know that the reference MPICH implementation (ch3/nemesis) does not actually perform and RMA until the end of the epoch, and so it has much more information and can process the entire epoch at once, atomically. But for other platforms where it makes sense to get communications (RMA) started as early as possible, that means the synchronization epoch needs to be handled differently, in a more complex way. Because we need to actually start communications when the PUT, GET, or ACCUMULATE is called, that means the synch epoch has to be setup before that point. It also means that there is less information available than if everything were queued and examined as-a-whole at epoch-end. There seems to be an expectation that one-sided operations will be faster than 2-sided, but this has not been the case due to the overhead of synchronization. Perhaps the 2-sided communication is just too fast, but it sure looks as though all this synchronization is just getting in the way.
_______________________________________________ Douglas Miller BlueGene Messaging Development IBM Corp., Rochester, MN USA Bldg 030-2 A410 [email protected] Douglas Miller/Rochester/IBM
Pavan Balaji <[email protected] ov> To Sent by: "MPI 3.0 Remote Memory Access mpi3-rma-bounces@ working group" lists.mpi-forum.o <[email protected]> rg cc
Subject 06/23/2010 08:57 Re: [Mpi3-rma] RMA synchronization AM optimization [was: Updated MPI-3 RMA proposal 1]
Please respond to "MPI 3.0 Remote Memory Access working group" <[email protected] pi-forum.org>
Hi Doug,
On 06/23/2010 08:01 AM, Douglas Miller wrote:
Right, the amount of code to maintain does increase, especially in the case that nothing is deprecated. My concern is for the performance of "common use" cases, which I think are where only one synchronization mode is used (is this not true? are there any "real" codes using this?).
From your description it is (somewhat) clear that the code complexity does increase, but to me it's not clear that it becomes more inefficient. Why does the possibility that an RMA operation might happen sometime later make it more inefficient?
They way the MPI standard is structured is that RMA operations can happen anytime between Win_create/alloc and Win_free, which seems like an "epoch" in terms of your expectation.
-- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Pavan Balaji
