Re: [mpiwg-rma] [Mpi-forum] 3/14: Formal Readings
Jim, this is a good idea. Small Change:
Advice to users: In the unified memory model, MPI_WIN_SYNC can be used ...
I would add the advice in MPI-3.0 on page 457, after line 3. Okay? Who of the RMA group is coming to the March meeting? Best regards Rolf ----- Original Message -----
From: "Jim Dinan" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Sent: Thursday, February 20, 2014 12:43:04 PM Subject: Re: [mpiwg-rma] [Mpi-forum] 3/14: Formal Readings
Hi Rolf,
I agree -- we have had several discussions in the RMA WG about this ambiguity, but I don't think we have a proposal for a clarification. I think the consensus was that MPI 3.0 is technically correct, albeit it hard to understand. Can we add an MPI_WIN_SYNC advice to users to your proposal?
Advice to users: MPI_WIN_SYNC can be used to order store operations and make store updates to the window visible to other processes. Use of this routine is necessary to ensure portable behavior when point-to-point, collective, or shared memory synchronization is used in place of an RMA synchronization routine. MPI_WIN_SYNC should be called by the writer before the non-RMA synchronization operation and by the reader after the non-RMA synchronization, as shown in Example X.YY.
~Jim.
On Thu, Feb 20, 2014 at 4:55 AM, Rolf Rabenseifner < [email protected] > wrote:
Jeff,
the problem is that we are in the unified model.
I expect that nobody would expect that
"the purposes of synchronizing the private and public window"
(from your cited text) is needed if
"public and private copies are identical",
see MPI-3.0 p436:37-40, which say
"In the RMA unified model, public and private copies are identical and updates via put or accumulate calls are eventually observed by load operations without additional RMA calls. A store access to a window is eventually visible to remote get or accumulate calls without additional RMA calls."
MPI-3.0 p456:3ff say
"In the MPI_WIN_UNIFIED memory model, the rules are much simpler because the public and private windows are the same. ..."
and especially p456:34-36
"This permits updates to memory with store operations without requiring an RMA epoch."
I read all this text and thought that I do not need any additional synchronization besides the (empty) pt-to-pt Messages. The members of the RMA working group convinced me that the MPI_WIN_SYNC is needed to guarantee that a locally visible X=13 may not be remote visible without the MPI_WIN_SYNC although the MPI-3.0 text clearly says "in the RMA unified model, public and private copies are identical".
Currently, there is no example in this section showing the behavior in the unified model with only using load/store, i.e. without any RMA call. All existing examples use some PUT or GET.
I tried to fill this gap to prevent any mis-interpretation of p436:37-40 and p456:3-p457:3.
Best regards Rolf
From: "Jeff Hammond" < [email protected] > To: "MPI WG Remote Memory Access working group" < [email protected] >
Cc: "Jeff Squyres" < [email protected] > Sent: Wednesday, February 19, 2014 7:19:14 PM Subject: Re: [mpiwg-rma] [Mpi-forum] 3/14: Formal Readings
Other than interactions that are unique to Fortran, I do not understand what is unclear about the following text from MPI-3:
"For the purposes of synchronizing the private and public window, MPI_WIN_SYNC has the effect of ending and reopening an access and exposure epoch on the window."
Thus, the valid usage is prescribed by its effective equivalence to "MPI_WIN_UNLOCK; MPI_WIN_LOCK;". I apologize if the WG has been sloppy in how we've discussed MPI_WIN_SYNC, but I do not feel the standard is ambiguous.
Now, if you are arguing that Fortran is a special problem for MPI_WIN_SYNC, then I will gladly support your argument that Fortran is a special problem for lots of things :-)
Jeff
On Wed, Feb 19, 2014 at 11:44 AM, Rolf Rabenseifner < [email protected] > wrote:
Jim,
Yes Jim, you are fully right and I updated ticket 413 according to your corrections. Thank you for your carefully reading and your corrections.
The reason for this ticket is very simple: Nothing about the use of MPI_Win_sync for the use-case in this example is really explained by MPI-3.0. I expect, that for MPI-4.0, the rules for RMA synchronization for shared memory windows must be revisited. But this would be another ticket.
Best regards Rolf
From: "Jim Dinan" < [email protected] > To: "MPI WG Remote Memory Access working group" < [email protected] > Cc: "Rolf Rabenseifner" < [email protected] >, "Jeff Squyres" < [email protected] > Sent: Monday, February 17, 2014 11:30:42 PM Subject: Re: [mpiwg-rma] [Mpi-forum] 3/14: Formal Readings
Rolf,
I think this ticket needs to be reviewed by the RMA WG before moving it forward. I would suggest updating the text to incorporate the following changes:
Example 11.13 demonstrates the proper synchronization in the unified memory model when a data transfer is implemented with load and store (instead of MPI_PUT or MPI_GET) and the synchronization between processes is performed using point-to-point communication. The synchronization between processes must be supplemented with a memory synchronization through calls to MPI_WIN_SYNC, which act locally as a processor-memory barrier. In Fortran, reordering of the MPI_WIN_SYNC calls must be prevented with MPI_F_SYNC_REG operations.
The variable X is contained within a shared memory window and X corresponds to the same memory location at both processes. The MPI_WIN_SYNC operation performed by process A ensures completion of the load/store operations issued by process A. The MPI_WIN_SYNC operation performed by process B ensures that process A's updates to X are visible to process B.
In the example, I don't see the reason for the second set of SYNC operations after B's read of X. If A updates X and B only reads it, the second send/recv synchronization should be sufficient. That is, B has not made any updates to X that need to be made visible A, and B's read of X will be ordered because of the send operation. The F_SYNC could still be needed to preserve this ordering.
~Jim.
On Mon, Feb 17, 2014 at 12:23 PM, Jeff Hammond < [email protected] > wrote:
Switching to the WG list so that everyone is involved...
I do not see adding an example as so urgent that it needs to be dealt with at the next meeting, given how overloaded the relevant people are.
Honestly, it is more likely to be read by users if the example and commentary on it are the subject of a blog post on Squyres' blog. At the very least, that will ensure Google indexes it and thus curious people will find it (as much cannot be said for the MPI standard itself).
Jeff
On Mon, Feb 17, 2014 at 10:50 AM, Rolf Rabenseifner < [email protected] > wrote:
Pavan,
do you put also #413 on the list. I believe, it's better to have it on the list although it is only an example and therefore the RMA group may put it on the errata without plenary. Please can you do all what is needed that it comes on the MPI-3.0 errata list.
Best regards Rolf
Pavan, thank you for supporting it in the March meeting (Rajeev will not be there). Is there a RMA WG Meeting at the March Forum Meeting? Will you do an MPI-3.0 errata plenary reading or will you put it into the errata by WG dicision, because it is only an example? In both cases #413 should be latest tomorrow on the agenda.
Because it is one block of text at one precise location, the ticket format may be enough formalism, i.e., no extra pdf.
From: "Jim Dinan" < [email protected] > To: "Main MPI Forum mailing list" < [email protected]
Sent: Monday, February 17, 2014 4:35:51 PM Subject: [Mpi-forum] 3/14: Formal Readings
Hi All,
The RMA and Hybrid working groups would like to put forward the following tickets for formal readings at the upcoming meeting:
#380 - Endpoints proposal
https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/380/mpi-repor...
Read by: Pavan Balaji
#349, #402, #404 - Address arithmetic proposal
https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/349/review-34...
Read by: David Goodell #369 - Add same_disp_unit info key for RMA window creation
https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/369/mpi-repor...
Please add these to the agenda. Unfortunately, I will not be able to attend this meeting, so I have included a contact person for each ticket.
Thanks! ~Jim. _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
-- Jeff Hammond [email protected] _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Rolf Rabenseifner
