Re: [Mpi3-rma] notes from 5pm Tuesday meeting @ July 2012 Forum
Thanks! I forgot this additional interface. It's added now, also see ticket #284. Torsten On Tue, Jul 17, 2012 at 09:38:08PM -0500, sreeram potluri wrote:
Need to check disp_unit change (Jim & Sreeram): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/284
disp_unit seems to be missing at the following locations
Page 409 Line 36 and Line 39 SUBROUTINE MPI_WIN_ALLOCATE_SHARED_CPTR(SIZE, INFO, COMM, BASEPTR, &
Group review (esp. Jim & Sreeram): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/187
Reviewed and looks fine.
Thanks Sreeram Potluri
On Tue, Jul 17, 2012 at 6:14 PM, Dave Goodell <[email protected]> wrote:
Discussed the complex types in COMPARE_AND_SWAP issue. "Fortran Integer" category is permitted, but "Complex" category is not, primarily because of width. Since "Fortran Integer" contains wide types, shouldn't we just permit "Complex" and "Floating point" as well? Consensus was to stick with the existing text which permits only "C integer, Fortran integer, Logical, Multi-language types, or Byte".
incorporate Jim suggested change (Torsten): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/271
we think we are unaffected, but need a second check (Jim): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/278
Double-check that C++ is not referenced in the RMA chapter (Pavan): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/281
Needs review (Dave): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/300
Think unaffected, but slim chance of Rput/Rget being affected (Pavan): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/317
Need to check implementation of various (4?) "flush is non-local" changes (Dave): https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/270
After the above items have all been dealt with, all chapter committee members should re-read the whole chapter in the *clean* document (the one _without_ the changebars and colored text) to look for obvious typos and inconsistencies.
-Dave
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- ### qreharg rug ebs fv crryF ------------- http://www.unixer.de/ ----- "I would rather have today's algorithms on yesterday's computers than vice versa." - Toint (contemporary)
participants (1)
Torsten Hoefler
