Re: [Mpi3-rma] RMA proposal 1 update
Are you referring to this email?
you allreduce(MPI_SUM, 1 million element integer vector == 4MB)? Then you know how many things you should have received and when you have received all of those you can enter a barrier?
If each origin (in a fence epoch) keeps track of the count(s) of RMA>> operations to each of its targets, then an allreduce of those arrays>> will>> tell each target how many operations were done to itself and can be>> used to>> determine completion. please help undestand this better, where does allreduce (in MPI terms) came into the picture here? There is no big vector. I want to do get_1, add_1, get_2, add_2, get_3, add_3 when there is not support for collective reduce in the network. Can this be worse than complete_1, complete_2, complete_3 Vinod.
From: [email protected] To: [email protected] Date: Wed, 19 May 2010 13:38:43 -0600 Subject: Re: [Mpi3-rma] RMA proposal 1 update Yes, it can be worse. See later emails in the thread… Keith From: [email protected] [mailto:[email protected]] On Behalf Of Vinod tipparaju Sent: Wednesday, May 19, 2010 1:34 PM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] RMA proposal 1 update I am very much for supporting collective remote completion. Many optimizations are possible here.
The question then turns to the "other networks". If you can't figure out remote completion, then the collective is going to be pretty heavy, right?
May be this will help make the point. When there is a network that does support a collective remote completion semantic (say, using its collective network reduce operation), would this functionality not help get better performance on that network? Would this functionality, for n collective completions, ever be worse than completion_1+completion_2+completion_3+...completion_n? If not, why not have it?
Date: Sun, 16 May 2010 20:32:36 -0600
Before doing that, can someone sketch out the platform/API and the implementation that makes that more efficient? There is no gain for Portals (3 or 4). There is no gain for anything that supports Cray SHMEM reasonably well (shmem_quiet() is approximately the same semantics as MPI_flush_all). Hrm, you can probably say the same thing about anything that supports UPC well - a strict access is basically a MPI_flush_all(); MPI_Put(); MPI_flush_all();... Also, I thought somebody said that IB gave you a notification of remote completion...
Keith
-----Original Message-----
[email protected]] On Behalf Of Jeff Hammond
Sent: Sunday, May 16, 2010 7:27 PM
Tortsten,
There seemed to be decent agreement on adding MPI_Win_all_flush_all
(equivalent to MPI_Win_flush_all called from every rank in the
communicator associated with the window) since this function can be
implemented far more efficiently as a collective than the equivalent
point-wise function calls.
Is there a problem with adding this to your proposal?
Jeff
On Sun, May 16, 2010 at 12:48 AM, Torsten Hoefler <[email protected]>
wrote:
Hello all,
After the discussions at the last Forum I updated the group's first
proposal.
The proposal (one-side-2.pdf) is attached to the wiki page
https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/RmaWikiPage
The changes with regards to the last version are:
1) added MPI_NOOP to MPI_Get_accumulate and MPI_Accumulate_get
2) (re)added MPI_Win_flush and MPI_Win_flush_all to passive target
mode
Some remarks:
1) We didn't straw-vote on MPI_Accumulate_get, so this function might
go. The removal would be very clean.
2) Should we allow MPI_NOOP in MPI_Accumulate (this does not make
sense
and is incorrect in my current proposal)
3) Should we allow MPI_REPLACE in
MPI_Get_accumulate/MPI_Accumulate_get?
(this would make sense and is allowed in the current proposal but
we
didn't talk about it in the group)
All the Best,
Torsten
bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ -----
Torsten Hoefler | Research Associate
Blue Waters Directorate | University of Illinois
1205 W Clark Street | Urbana, IL, 61801
NCSA Building | +01 (217) 244-7736
mpi3-rma mailing list
Jeff Hammond
Argonne Leadership Computing Facility
[email protected] / (630) 252-5381
participants (1)
Vinod tipparaju
