Re: [Mpi3-rma] MPI-3.1 RMA planning
On Thu, Jul 26, 2012 at 11:18:54AM -0500, Pavan Balaji wrote:
On 07/26/2012 08:52 AM, Pavan Balaji wrote:
I would like to add some info arguments to the list of things to consider. I don't have the full list at this point, but we have the "same_size" argument for create and allocate. However, we have no "same_displ_unit", which goes by the same rationale. We could also add some info arguments to dynamic windows to mitigate some of the implementation issues (allow optimized implementations on RMA systems).
Sounds good.
What does "same_size" mean for heterogeneous systems?
The size is in bytes, it's clearly defined in the draft standard.
If I give 100 * sizeof(int) on both sides, that will not be the same size on a heterogeneous system. This might be worth a user advise. Well, this is a user error.
A few other things that we noticed:
1. The standard currently states, "A put or accumulate must not access a target window once a load/store update or a put ... ". The term "load/store update" doesn't make sense. This has caused a major confusion even to the RMA working group, for example on the slide that we put together for compatibility between load, store, put, get, accumulate, etc. It should really say "load/store accesses" -- that is, simultaneous loads and PUTs are not allowed in the SEPARATE model. Ah, I thought we cleaned all of those things up - one more straggler, probably a ticket 0 (will not do it now since we're supposed to be finalized).
2. The disp_unit is a weird semantic which is really meant to demonstrate what datatype I will be using. We are jumping through hoops to get the same_size and same_disp_unit measures which make little sense on heterogeneous systems. The correct way to do this would have been to not take a disp_unit parameter at all, and instead take a MPI_Datatype parameter. In this case, two different processes can give MPI_INT but have different type sizes. That adds better safety checks in MPI. Maybe, but for some reasons, RMA windows are completely specified with bytes. I am not sure what the reason for this was.
Unfortunately, all our window creation routines are screwed up in this manner. We should consider adding MPI_Win_create_type, MPI_Win_allocate_type, MPI_Win_allocate_shared_type in MPI-3.1 and deprecating the older routines. It would have been much better to do this in 3.0, but it's not a small change. Ugs, this makes me shiver. I agree in principle, but it's ugly.
Torsten -- ### qreharg rug ebs fv crryF ------------- http://www.unixer.de/ ----- Torsten Hoefler | Performance Modeling and Simulation Lead Blue Waters Directorate | University of Illinois (UIUC) 1205 W Clark Street | Urbana, IL, 61801 NCSA Building | +01 (217) 244-7736
participants (1)
Torsten Hoefler
