Re: [mpiwg-rma] MPI_Win_create on unmapped memory?
It was certainly the intent that the memory be allocated. Specifically, if a is the pointer and the region is of length L, then (assuming char *a and ) a[0] … a[L-1] must be valid r and l values at the point of the call. Bill William Gropp Director and Chief Scientist, NCSA Thomas M. Siebel Chair in Computer Science University of Illinois Urbana-Champaign
On Jan 2, 2018, at 1:52 PM, Jeff Hammond <[email protected]> wrote:
If a user passes a (base,size) pair that corresponds to a range of addresses that are not allocated and/or mapped, is that a correct MPI program?
The only text I can find that implies that buffers passed to MPI_Win_create have to be allocated is the following, assuming that one interprets "existing memory" this way.
"Each process specifies a window of existing memory that it exposes to RMA accesses by the processes in the group of comm." (MPI 3.1 11.2.1)
The Fortran-specific text is similarly suggestive, but it only says that a user can pass a simply contiguous array, not that such a thing is required.
"In Fortran, one can pass the first element of a memory region or a whole array, which must be ‘simply contiguous’"
Jeff
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/ <http://jeffhammond.github.io/>_______________________________________________ mpiwg-rma mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-rma
participants (1)
William Gropp
