Re: [Mpi3-rma] RMA proposal 1 update
Right. I think all of the "suggested" implementations do not need a special allfenceall interface because they are essentially variations on the "fence or allfence, then barrier" idea. To justify a new interface there must be some way that some implementation can use hardware-specific optimizations that are not exposed through the existing pt2pt and collective primitives. I'm just say that experience tells me we should be able to do something interesting in this area on BG/P. I agree that is not a very compelling argument, but I haven't the time to come up with a full bgp design. :) Maybe Jeff, myself, and Brian can hash something out that is a little more real. I probably didn't wordsmith this very well, but I mean to say is that some hardware features are only available to a platform at the very lowest levels of the software stack. For example, on BG/P we have the raw DMA SPI which represent 100% of the hardware features, but the public C interface for DCMF doesn't provide all these details to its users (MPICH2 DCMFd "glue" and ARMCI). For DCMF we have the luxury of adding interfaces as the needs arise, and we would design a new interface so that the guts of DCMF could use as many SPI tricks as possible to implement the semantics of the interface for the user, as opposed to reusing existing DCMF C API functions to implement the semantics o the interface. Deterministic routing performance .. Well, it depends on what you are trying to do. :) For bisection bandwidth you'll definitely need dynamic routing to avoid network hotspots. However, deterministic routing allows us to play games to eliminate, avoid, or limit acks or active remote participation. The problem with counter arrays or any data structure that grows with the size of the job is you just run out of memory. This shows up on BG/P in virtual node mode at scale where every additional 32 bits of a data structure will result in an additional 1MB of memory usage - and there is only 256 MB available per rank in vnm! We use deterministic routing to provide a "remote completion" callback event for DCMF_Put that only uses the dma hardware - no cores - so that the put is truly one sided. The put packets are all deterministically routed and then followed by a deterministically routed "remote get" packet. The target dma will process the remote get packet only after it has processed all of the put packets. When the primitive get operation completes on the origin we know that all of the previous put packets have been pulled from the network and written to memory on the target node. I could go on and on, but don't want to pollute this thread any further. :) Michael Blocksome Blue Gene Messaging Advanced Systems Software Development [email protected] From: "Underwood, Keith D" <[email protected]> To: "MPI 3.0 Remote Memory Access working group" <[email protected]> Date: 05/24/2010 02:09 PM Subject: Re: [Mpi3-rma] RMA proposal 1 update I think the discussion of the three possible implementations below misses the mark a bit. Any low level messaging layer (DCMF, LAPI, even "MPI") that can optimize the allreduce and barrier operations could implement the allfenceall operation as described below. Even though DCMF - which what MPICH2 on BG/P is based on - uses the BG/P collective network, it still is *only* a fast allreduce that has benefits over other pt2pt allreduce algorithms and not very interesting when considering how an allfenceall would be implemented. If we look at any exascale goal(s), as Jeff mentioned earlier, we'll see that any time an application or middleware needs to track counters we won't get the scaling required (assuming the allfenceall is flexible and not restricted to only "comm_world" operations). What is needed is an interface that allows low level software to take advantage of any hardware or network features that would enable a "counter-less" allfenceall implementation. On BG/P, this would probably take advantage of features such as the torus dimensions of the network, the (configurable) deterministic packet routing, the "deposit bit" in the packet header, etc. I'm not saying I have any specific design in mind, just that experience tells me that we should be able to do something cool in this space supported by the BG hardware which would eliminate the need for software accounting. The forum was relatively clear in requiring an implementation for new calls. In theory, that implementation kind of has to fit with the motivation for the call. Saying “this would give performance advantages if we did something special, but this implementation doesn’t give those advantages” isn’t particularly compelling. The implementations you mention from earlier in the thread could colloquially be called “the way it is done now”, “the way IBM suggested”, and “the way Keith suggested that may be completely ridiculous ”. Better implementations would certainly be interesting to discuss. BTW, in many of the RMA discussions, it has been asserted that using the deterministic packet routing is a terrible performance hit. Is that not an issue? If there was an allfenceall interface, then low level message could do whatever it takes to get performance and scaling. Without the allfenceall interface middleware is forced to use one of these platform independent algorithms (allreduce, barrier, etc) and accept any inherent scaling and performance restrictions. I don’t understand this comment. Without the allfenceall, I’m not sure how you would call a collective to do a fenceall at a given node (fenceall would complete all outstanding requests from a given rank). I’m also not sure why the difference between an allfenceall and a fenceall makes a difference between platform specific and platform independent approaches. Keith_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Michael Blocksome
